3DR Iris Plus Quadcopter Propeller Replacement
    1. 3DR Iris Plus Quadcopter Propeller Replacement, Battery: step 1, image 1 of 1
      • Power off the drone by holding down the power button.
      • Remove the battery by disconnecting it from the main battery connector.
      • Press the power button again to ensure all electricity is discharged.
      • This step is imperative as it is dangerous to handle drone components with a running current!
      Ask FixBot
    1. 3DR Iris Plus Quadcopter Propeller Replacement, Propeller: step 2, image 1 of 2 3DR Iris Plus Quadcopter Propeller Replacement, Propeller: step 2, image 2 of 2
      • Take note of the propeller cap color (either black or silver).
      • Hold down the motor assembly and twist the propeller clockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
      • Hold down the motor assembly and twist the propeller counterclockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
      • This is the motor assembly.
      Ask FixBot
    2. 3DR Iris Plus Quadcopter Propeller Replacement: step 3, image 1 of 2 3DR Iris Plus Quadcopter Propeller Replacement: step 3, image 2 of 2
      • Ensure that the propeller cap color (black or silver) matches the propeller screw cap color.
      • There are two different types of propellers so make sure you're using the correct one.
      Ask FixBot
To reassemble your device, follow these directions in reverse order.
Wanjiku Gichigi
196 Reputation
1 Guide authored
Cal Poly, Team S7-G5, Regan Winter 2020 Member of Cal Poly, Team S7-G5, Regan Winter 2020
CPSU-REGAN-W20S7G5
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 20
All Time: 758
