3DR Iris Plus Quadcopter Bottom Shell Replacement
    1. 3DR Iris Plus Quadcopter Bottom Shell Replacement, Bottom Shell: step 1, image 1 of 2 3DR Iris Plus Quadcopter Bottom Shell Replacement, Bottom Shell: step 1, image 2 of 2
      • Remove the eight 11mm screws attaching the underbody of the drone using the 2mm Hex screwdriver/key.
      Ask FixBot
    2. 3DR Iris Plus Quadcopter Bottom Shell Replacement: step 2, image 1 of 3 3DR Iris Plus Quadcopter Bottom Shell Replacement: step 2, image 2 of 3 3DR Iris Plus Quadcopter Bottom Shell Replacement: step 2, image 3 of 3
      • Remove the two larger, 12mm screws attached to the Go Pro mount using the 3mm Hex screwdriver/key.
      • Lift to remove the mount.
      Ask FixBot
    3. 3DR Iris Plus Quadcopter Bottom Shell Replacement: step 3, image 1 of 3 3DR Iris Plus Quadcopter Bottom Shell Replacement: step 3, image 2 of 3 3DR Iris Plus Quadcopter Bottom Shell Replacement: step 3, image 3 of 3
      • Feed both wires through the grill of the bottom shell.
      • Lift to remove the shell.
      • There are two cables tethering the shell to the body of the drone. It is difficult and unnecessary to remove them. Simply lay the shell to the side.
      Ask FixBot
Evan Witulski
349 Reputation
3 Guides authored
Cal Poly, Team S7-G5, Regan Winter 2020 Member of Cal Poly, Team S7-G5, Regan Winter 2020
CPSU-REGAN-W20S7G5
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 17
All Time: 422
