Up to 20% off select tools
3DO FZ-1 Disassembly Guide
Views: 10K
View statistics:
Past 24 Hours:
8
Past 7 Days:
43
Past 30 Days:
219
All Time:
10,151
Comments: 2
2 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Today we are going to take apart the Panasonic version of the FZ-1 R.E.A.L 3DO Interactive Multiplayer home video game console. Originally released in 1993, the 3DO was known as an early adopter of CD-Drive games, and for the ability to display photos and play music.
    1. 3DO FZ-1 Disassembly Guide, Lets Begin!: step 1, image 1 of 3 3DO FZ-1 Disassembly Guide, Lets Begin!: step 1, image 2 of 3 3DO FZ-1 Disassembly Guide, Lets Begin!: step 1, image 3 of 3
      • Here we have the front view of the FZ-1 3DO.
      • Note the ports on the back of the unit. The FZ-1 comes with RF, S-Video, and Composite Outputs, as well as a expansion port on the back of the unit.
      • A larger 2nd expansion slot can be found on the right side of the unit.
      Ask FixBot
    2. 3DO FZ-1 Disassembly Guide, Outer Casing: step 2, image 1 of 1
      • Flip the unit over, so that the bottom side of the case is facing up towards you, exposing the four screws casing screws.
      • Remove the four #2 Phillips Screws from the casing.
      • After the screws are removed, flip the unit back over while holding the top and bottom pieces of the case together.
      Ask FixBot
    3. 3DO FZ-1 Disassembly Guide, Top Casing: step 3, image 1 of 1
      • Remove the top portion of the case to expose the internal components.
      Ask FixBot
    4. 3DO FZ-1 Disassembly Guide, Disc Drive: step 4, image 1 of 3 3DO FZ-1 Disassembly Guide, Disc Drive: step 4, image 2 of 3 3DO FZ-1 Disassembly Guide, Disc Drive: step 4, image 3 of 3
      • Remove the 2 #1 Phillips Screws from the back of the Disc Drive Shield.
      • Using a Spudger, carefully pry up the four metal tabs to remove the disc drive cover.
      • Remove the 4 #2 Phillips Screws.
      • Remove the disc drive shield, and the two bars you just unscrewed.
      Ask FixBot
    5. 3DO FZ-1 Disassembly Guide: step 5, image 1 of 1
      • Remove the 5 #1 Phillips Screws holding the CD Drive to the motherboard.
      • Carefully unplug the two ribbon cables connecting the CD drive to the motherboard.
      • You can now safely remove the CD drive from the case.
      Ask FixBot
    6. 3DO FZ-1 Disassembly Guide: step 6, image 1 of 2 3DO FZ-1 Disassembly Guide: step 6, image 2 of 2
      • Remove the 11 #1 Phillips Screws connecting the metal shield to the motherboard.
      • Remove the metal shield.
      • Remove the metal cover from the expansion port.
      Ask FixBot
    7. 3DO FZ-1 Disassembly Guide: step 7, image 1 of 1
      • Remove the #1 Phillips Screw from back port cover, and then remove the cover.
      Ask FixBot
    8. 3DO FZ-1 Disassembly Guide: step 8, image 1 of 2 3DO FZ-1 Disassembly Guide: step 8, image 2 of 2
      • Remove the plastic cover, power and eject buttons found at the front end of the unit.
      Ask FixBot
    9. 3DO FZ-1 Disassembly Guide: step 9, image 1 of 2 3DO FZ-1 Disassembly Guide: step 9, image 2 of 2
      • Unplug the power and fan cables from the motherboard.
      • Remove the 2 #2 Phillips Screws holding the power supply to the case.
      • The electric screwdriver comes in handy loosening the PSU screws on the FZ-1.
      • Remove the power supply and fan from the case.
      Ask FixBot
    10. 3DO FZ-1 Disassembly Guide: step 10, image 1 of 1
      • Unplug the ribbon cable connecting the motherboard to the controller port board.
      • Remove the controller board and motherboard.
      Ask FixBot
      • Remove the metal shield at the bottom of the case. Mission complete!
      Ask FixBot
8 other people completed this guide.
Author
with
Ben Eccles
963 Reputation
1 Guide authored
2 Guide Comments
Can you tell me what size the screws are? I need to order a replacement set for my FZ-1
Richard Poll - Reply Share
I thought I couldn't fix this old appliance in my house. Until I came across this site! Thank you. :)
Jellyna Studio - Reply Share
Past 24 Hours: 8
Past 7 Days: 43
Past 30 Days: 219
All Time: 10,151
