Up to 20% off select tools
360fly 4K Battery Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
105
All Time:
3,875
Comments: 8
3 comments on steps, 5 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This page will guide you on the replacement of the battery on your 360fly 4K camera.
    1. 360fly 4K Battery Replacement, Battery: step 1, image 1 of 1
      • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
      Ask FixBot
    2. 360fly 4K Battery Replacement: step 2, image 1 of 1
      • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
      Ask FixBot
    3. 360fly 4K Battery Replacement: step 3, image 1 of 2 360fly 4K Battery Replacement: step 3, image 2 of 2
      • Gently pry the plastic ring from around the charging plate with the metal spudger.
      • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
      Ask FixBot
    4. 360fly 4K Battery Replacement: step 4, image 1 of 1
      • Remove the five 2 mm screws using a T4 screwdriver.
      • Pull off the charging plate assembly.
      Ask FixBot
    5. 360fly 4K Battery Replacement: step 5, image 1 of 2 360fly 4K Battery Replacement: step 5, image 2 of 2
      • Gently pry the plug off the port on the circuit board with a plastic opening tool.
      • Remove the four 2 mm screws using a T4 screwdriver.
      • Remove the circuit board from the device.
      Ask FixBot
    6. 360fly 4K Battery Replacement: step 6, image 1 of 3 360fly 4K Battery Replacement: step 6, image 2 of 3 360fly 4K Battery Replacement: step 6, image 3 of 3
      • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
      • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
      • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
      • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
      Ask FixBot
2 other people completed this guide.
Author
with
Jacob Herron
463 Reputation
3 Guides authored
IUPUI, Team S5-G3, Baechle Fall 2017 Member of IUPUI, Team S5-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G3
3 Members
36 Guides authored
5 Guide Comments
Wich one battery Can I use to replace It?
Marco Pereira - Reply Share
Where can i purchase a battery
john hernandez - Reply Share
I would like to purchase a 360 fly battery
Where can I buy the battery?
Mark - Reply Share
Battery part number?
R H. - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 105
All Time: 3,875
