Up to 20% off select tools
3. Extruder
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
69
All Time:
69
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
3. Extruder
    1. 3. Extruder, How to insert nuts: step 1, image 1 of 3 3. Extruder, How to insert nuts: step 1, image 2 of 3 3. Extruder, How to insert nuts: step 1, image 3 of 3
      • Inserting Hex Nuts: To assure that hex nuts are properly seated, do the following:
      • Add a washer to the screw, to avoid damaging the printed part.
      • Insert the screw through the hole on the opposite side to the hexagonal cavity.
      • Thread the hex nut onto the screw and tighten the screw.
      • Ensure the hex nut is aligned with the hex cavity while tightening.
      • When the nut is fully seated, remove the screw being careful not to dislodge the nut.
      • Inserting Nyloc Nuts: You can use the same method as used for the hex nuts.
      • Inserting Square Nuts: They tend to fall out if the piece holding them is inverted. After they are inserted, check that they are properly seated by inserting a screw to engage that nut.
      Ask FixBot
    2. 3. Extruder, Extruder parts: step 2, image 1 of 2 3. Extruder, Extruder parts: step 2, image 2 of 2
      • extruder_body
      • extruder_cover
      • extruder_idler
      • fs_lever
      • nozzle_fan_duct (with print support removed)
      • filament_sensor_cover
      • hotend_collet_clip
      Ask FixBot
    3. 3. Extruder, X carriage parts: step 3, image 1 of 1
      • x_carriage
      • x_carriage_back (two parts)
      • cable_guide_back (part a and b)
      Ask FixBot
    4. 3. Extruder, Extruder motor: step 4, image 1 of 3 3. Extruder, Extruder motor: step 4, image 2 of 3 3. Extruder, Extruder motor: step 4, image 3 of 3
      • Locate the extruder motor so the wires face to the left. Rotate the shaft so that the flat is facing up.
      • Mount the Bondtech pulley on the extruder motor shaft so that the geared portion is furthest from the motor body and with the set screw contacting the flat portion of the shaft.
      • The motor shaft should protrude from the pulley by approximately 1mm.
      • Secure the set screw to avoid the gear moving. We will fine tune the position later.
      • Verify the orientation of the motor cables.
      • Secure the extruder motor to the extruder_body using two M3x25 screws.
      • Verify the motor cables orientation
      Ask FixBot
    5. 3. Extruder, X carriage preparation: step 5, image 1 of 2 3. Extruder, X carriage preparation: step 5, image 2 of 2
      • Insert three M3 hex nuts
      • Insert two M3 nylock hex nuts
      Ask FixBot
    6. 3. Extruder, X carriage assembly: step 6, image 1 of 3 3. Extruder, X carriage assembly: step 6, image 2 of 3 3. Extruder, X carriage assembly: step 6, image 3 of 3
      • Verify that the M3x25mm screws are snug
      • Slide an M3 square nut into the extruder_body.
      • Using an M3x10 screw attach the extruder_body to the x_carriage.
      • Using an M3x40 screw with an M3 washer attach the extruder_body to the x_carriage.
      • Verify that extruder_body and x_carriage are correctly aligned. Adjust if necessary with the M3x10 and M3x40 screws
      Ask FixBot
    7. 3. Extruder, Filament sensor assembly: step 7, image 1 of 3 3. Extruder, Filament sensor assembly: step 7, image 2 of 3 3. Extruder, Filament sensor assembly: step 7, image 3 of 3
      • Verify that the filament_sensor_lever and the filament sensor pocket on top of the extruder_body does not have strings and are well printed. Clean up if necessary.
      • Insert the longer magnet (20x6x2mm) inside the filament_sensor_lever.
      • Place the smaller magnet (10x6x2mm) so that it is attracted to the filament_sensor_lever. The smaller magnet should be on the flat side of the lever.
      • Remove the smaller magnet from the filament_sensor_lever, taking care to keep the orientation the same. Insert the smaller magnet with the same orientation into the extruder_body. DO NOT insert the filament_sensor_lever yet.
      • Verify that the smaller magnet is fully pressed into its cavity.
      Ask FixBot
    8. 3. Extruder, Filament sensor assembly: step 8, image 1 of 3 3. Extruder, Filament sensor assembly: step 8, image 2 of 3 3. Extruder, Filament sensor assembly: step 8, image 3 of 3
      • Insert the steel ball in the dedicated pocket of the extruder_body.
      • Verify the steel ball is rolling smoothly and easily, inside its pocket.
      • Insert the filament_sensor_lever.
      • You can use a flat screwdriver to keep the steel ball in its pocket when inserting the filament_sensor_lever.
      • Test the filament_sensor_lever is moving correctly with a piece of filament.
      Ask FixBot
    9. 3. Extruder, Filament sensor assembly: step 9, image 1 of 2 3. Extruder, Filament sensor assembly: step 9, image 2 of 2
      • In order to avoid electrostatic discharge to the filament sensor, touch something metallic that is linked to the ground. Like pipework or a faucet.
      • Carefully secure the Prusa IR sensor with an M2x8 screw. Do not over tighten.
      • Adjust the Prusa IR sensor to make sure that it is parallel to the border of the pocket. Finish tightening the screw; it only needs to be tightened sufficiently to hold the sensor in place
      Ask FixBot
      • With a piece of filament, verify the filament_sensor_lever is working smoothly.
      Ask FixBot
    10. 3. Extruder, Filament sensor cover assembly: step 11, image 1 of 1
      • Install and secure the filament_sensor_cover with an M3x10 screw.
      Ask FixBot
    11. 3. Extruder, Extruder idler preparation: step 12, image 1 of 2 3. Extruder, Extruder idler preparation: step 12, image 2 of 2
      • Locate the Bondtech drive gear. This is the one that has NO set screw.
      • Lubricate the needle bearings with a dab of lithium based grease
      • Slide the two Bondtech needle bearings into the Bondtech drive gear.
      Ask FixBot
    12. 3. Extruder, Extruder idler preparation: step 13, image 1 of 3 3. Extruder, Extruder idler preparation: step 13, image 2 of 3 3. Extruder, Extruder idler preparation: step 13, image 3 of 3
      • Place the idler gear into the extruder_idler. Note the orientation of the teeth.
      • Make sure that both needle bearings are still present in the idler gear.
      • Insert the shaft from the direction shown in the diagram. Fully insert the shaft, it should be flush with the printed part, else the the idler will not close properly.
      • Insert a square nut in the lateral pocket.
      • Double check the orientation of the gears.
      • Double check that no needle bearing has fallen out during these steps.
      Ask FixBot
    13. 3. Extruder, Extruder idler assembly: step 14, image 1 of 2 3. Extruder, Extruder idler assembly: step 14, image 2 of 2
      • Slide an M3 washer on an M3x40 screw.
      • Insert the screw into the top, left, hole of the x_carriage, until it protrudes just enough for you to place an M3 washer on it.
      • Carefully place an M3 washer on the end of the screw.
      • Carefully slide the extruder_idler into the opening, taking care not to displace the M3 washer and insert the screw to act as the hinge for the idler door..
      • Gently tighten the screw into the extruder motor, the extruder_idler must rotate freely.
      Ask FixBot
    14. 3. Extruder, Prepare the PTFE tube: step 15, image 1 of 1
      • The Bear extruder uses a PTFE tube length of 50mm. It is the same PTFE tube than MK2S, MK2.5 (non-S) and MK3 (non-S). The original Prusa MK2.5S or MK3S extruder is using a PTFE tube length of 44.2mm which will be too short for the Bear extruder.
      • You should have prepared the PTFE tube during guide 1. Preflight check and disassembly. Make sure you have followed those steps.
      Ask FixBot
    15. 3. Extruder, Hotend assembly: step 16, image 1 of 3 3. Extruder, Hotend assembly: step 16, image 2 of 3 3. Extruder, Hotend assembly: step 16, image 3 of 3
      • Hotend wires are not visible on these images. Use the heatblock to orientate the hotend correctly.
      • Make sure your PTFE tube length is 50mm.
      • Push the collet (black plastic part) down and fully insert the PTFE tube. Whilst pressing the PTFE into the hotend, lift the collet upwards, to lock the PTFE tube in place
      • Insert the hotend_collet_clip. This prevents the collet from loosening and keeps the PTFE tube locked in place.
      • Insert the hot end into the extruder_body so that the heater and thermistor wires are properly oriented.
      • Note the position of the heater and thermistor wires.
      Ask FixBot
    16. 3. Extruder, Extruder cover assembly: step 17, image 1 of 3 3. Extruder, Extruder cover assembly: step 17, image 2 of 3 3. Extruder, Extruder cover assembly: step 17, image 3 of 3
      • Insert one M3 square nut
      • Insert one M3 hex nut
      • Insert two M3x40 screw to lock the hotend in place
      • Check that the hotend has not rotated, is perpendicular to the extruder body and is correctly oriented. Adjust if necessary.
      Ask FixBot
    17. 3. Extruder, Hotend fan assembly: step 18, image 1 of 3 3. Extruder, Hotend fan assembly: step 18, image 2 of 3 3. Extruder, Hotend fan assembly: step 18, image 3 of 3
      • Carefully route the motor wires as shown in the figure.
      • Make sure the wires sit correctly in the channel.
      • This surface will be touching the extruder_body. It is the side with the manufacturers label on it. The wires come out from this side and the fan should be oriented so that they point towards the rear of the extruder.
      • Carefully route the hotend fan wires in the x_carriage.
      • Attach the hotend fan with four screws. Follow the screw type according to your hotend fan:
      • Sunon & Delta : M3x16 button head screw
      • Noctua : M3x14 socket head screw
      • Check that no wires are pinched. Check the orientation of the hotend fan, the air should be blowing over the hotend heatsink. On the edge of the fan body, there are usually two arrows, indicating the direction of rotation and direction of flow. Ensure that the arrow indicating flow is pointing in towards the hotend.
      Ask FixBot
    18. 3. Extruder, Bondtech gear alignment: step 19, image 1 of 3 3. Extruder, Bondtech gear alignment: step 19, image 2 of 3 3. Extruder, Bondtech gear alignment: step 19, image 3 of 3
      • Open the extruder_idler
      • Insert a piece of 1.75 mm filament through the extruder_body into the PFTE tube.
      • Using the Bondtech set screw, carefully center the filament on the drive teeth.
      • Tighten the set screw. Don't tighten too much as you will damage the thread.
      • Remove the filament.
      • This is a good time to put a dab of lithium based grease on the gears. Make sure that you do not get any grease on the drive teeth.
      Ask FixBot
    19. 3. Extruder, Extruder idler tensioner screw: step 20, image 1 of 2 3. Extruder, Extruder idler tensioner screw: step 20, image 2 of 2
      • Make sure that you have completely removed the filament from the extruder_body.
      • Slide an extruder spring onto an M3x40 screw.
      • Close the extruder_idler door.
      • Slide the screw with the extruder spring into the extruder_body.
      • Tighten the screw into the extruder_idler until the head is flush with the surface of the body.
      • If you have trouble closing the extruder_idler, try rotating the Bondtech idler gear, with a finger, to ensure that the gears are meshed.
      Ask FixBot
    20. 3. Extruder: step 21, image 1 of 1
      • Slide an M3 washer on an M3x18 screw. Do the same for another M3x18 screw.
      • Attach the print fan using the screws
      • Be careful not to over tighten to avoid damaging the fan.
      Ask FixBot
    21. 3. Extruder, PINDA probe assembly: step 22, image 1 of 3 3. Extruder, PINDA probe assembly: step 22, image 2 of 3 3. Extruder, PINDA probe assembly: step 22, image 3 of 3
      • Place a square nut in the extruder_body for the pinda_mount.
      • Slide an M3x10 screw into the pinda_mount and engage the square nut, but do not tighten yet.
      • Insert the PINDA into the mount so that the sensor end is approximately 12mm below the bottom of the pinda_mount. Tighten the screw just enough to keep the PINDA from falling out. The optimum PINDA position will be adjusted later.
      • Route the PINDA wires
      • Route the print fan wires
      • Secure the cables with a zip tie. Be sure to leave some slack since the PINDA position will need to be adjusted later.
      • This is the peferred example of how the PINDA and print fan cables should be wired.
      Ask FixBot
    22. 3. Extruder, Print fan shroud assembly: step 23, image 1 of 2 3. Extruder, Print fan shroud assembly: step 23, image 2 of 2
      • Make sure you have broken the support for the nozzle_fan_duct.
      • Insert the print shroud. If necessary, slightly unscrew the print fan.
      • Use an M3x10 screw to attach the shroud and secure the print fan.
      Ask FixBot
    23. Ask FixBot
Finish Line
Greg Bear
8,773 Reputation
35 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 69
All Time: 69
