Orientate the heater block at 135° as shown in the image.
Install heater and thermistor as shown in the image.
Insert two M3 square nuts in vertical on the back of the stepper
Insert two M3 square nuts on top front of stepper
Verify you do not have M3 square nuts in those holes
Insert two M3 hex nuts in body_front
Insert three M3 nylock nuts in body_back
Insert two square nuts in body_back
Insert one square nut in body_back
Secure the nozzle fan to the body_front with an M3x25 screw and the printed part nozzle_fan_spacer.
Tighten an M3x8 screw
Secure the nozzle_fan_duct with an M3x10 screw
Finish to secure the nozzle fan with an M3x25 screw and a washer
Assemble body_back with two M3x8 screws. Make sure to not pinch any wires
Secure the body_back with two M3x40 screws
Connect the stepper cable and route them in the top groove with the nozzle fan wires
Secure the cables with the cable_cover and an M3x10 screw
Insert five M3 hex nuts in the back of the x_carriage
Insert an M3 square nut on the back of the pinda_mount
Install the pinda_mount on the body_back and secure it with an M3x10 screw
Secure the Pinda on the pinda_mount with an M3x10 screw. The PINDA should be out in the bottom by approx. 10mm
Route the stepper motor, nozzle fan and PINDA as shown in the second image. Make sure to not pinch any wires
Attach the x_carriage on the body_back with two M3x18 screws
And one M3x10
Attach the Hemera fan with the self tapping screws provided with your Hemera.
Create a small loop for the fan wires to reduce tension on the cable
Route all wires as shown in the last image
Attach the BearMera on the Bear X axis (only the bearings are visible on this picture)
Make sure the nozzle fan, stepper motor, pinda and hotend fan cables are routed in between the smooth rods
Close the top bearings using four M3x18 screws and the top of x_carriage_back.
Route the belt
Add the bottom of x_carriage_back as shown in the second image. Make sure to not pinch any wires. You should not have to use any force to close it
Secure the x_carriage_back with an M3x18 screw
And two M3x10 screws
Screw cable_guide_back_a and cable_guide_back_b to the x_carriage using an M3x40 screw
The M3x40 screw should be at a slight angle to the horizontal while you are tightening it.
Add the textile sleeve as explained in the Prusa manual for MK3S (steps 62 to 64): https://manual.prusa3d.com/Guide/5.+E-ax...
Verify the wire positions and adapt them if they are not matching the pictures. Then, connect your extruder stepper to your Rambo Mini or Einsy Rambo
MK3 only: As the Hemera hotend fan works with 24V you will need to connect it differently (Prusa uses 5V fans). You can use jumper wires or build an adapter.
+24V goes to pin1 of J19 connector
Ground goes to left pin of the hotend fan connector
MK2.5(S) only: You need to remove the adapter for the hotend fan (black-red-yellow adapter) and plug the fan directly into the hotend fan connector
+12V goes to top pin of the hotend fan connector
Ground goes to bottom pin of the hotend fan connector
MK2(S) only: Connect the hotend fan to the Rambo Mini just like on stock Prusa MK2(S). Make sure the polarity is correct.
Follow the original Prusa manual to connect the other cables of your extruder to the Mini-Rambo / Einsy-Rambo:
Congratulations you have finished this chapter :-)
Go to the next chapter: 4. Adjustments
