This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓As this device is relatively simple, the problems are quite easy to identify. Take the time, however, to read the method to perform a repair in good conditions. Follow along by browsing the two guides on the functions and how it works. You will thus maximize your chances of success.
Due to its design, the problems that occur are almost exclusively electrical or electronic in nature. They concern the heating element, the switch, the power cord, and the electronic part.
The hair dryer, also known as a blow dryer in some regions, is an electromechanical device designed to dry hair using hot or cold air.
A hair dryer primarily consists of a motor that powers a blower mechanism and an electrical resistance, so that air drawn in on one side exits the other at a higher temperature. Read more on Wikipedia
The airflow produced as well as the temperature of this airflow can be modified using a multi-position switch or via a potentiometer (more rare).
Hair dryers consist of a body Reference 2 provided with a handle that receives the power cable Reference 4 and is equipped with a multi-position switch Reference 5
The back of the device is provided with a grille Reference 3 protecting a dust filter. The front is fitted with a diffuser Reference 1 which can be removable.
Hair dryers use a motor-driven fan and a heating element to transform electric energy into convective heat. The whole mechanism is very simple. The video (FR) shared in the introduction shows the general principle. You can find it, along with other videos, on Mozaik Education (FR).
When you plug in the hair dryer and flip the switch, current circulates in the hair dryer. First, the circuit powers the heating element.
In most hair dryers, the heating element is a bare coiled wire. In more expensive models, more sophisticated materials might be used, such as a ceramic coating entwined in tourmaline. The electric current then makes the small electric motor run, which powers the fan.
The flow of air generated by the fan goes through the body of the hair dryer, above and through the heating element. When air flows on and through the heated element, the generated heat warms up the air by forced convection. Hot air flows through the extremity of the front nozzle.
Hair dryers are mostly identical in their design and choice of components. The electrical/electronic part is more or less elaborate, but rather similar regardless of the model.
The teardown view schema shows the different elements that make up most hair dryers: 1. Grid with a removable nozzle (not shown here), 2. Insulated support cone made of mica, which supports the heating resistor. 3. Heating resistor made of nichrome, 4. Diode bridge
5. Air entry filter, 7. Fan blade, 8. Cold air button, 9. Speed switch, 10. Power supply cable
Nichrome is a poor electricity conductor compared to copper wire. It gives the alloy enough resistance to heat up with the circulating current. It doesn't oxidize when heated. Other metals, such as iron, would quickly rust at temperatures used in toasters and hair dryers.
As previously stated, each model uses a solution that varies depending on the brand. It would be difficult to study each one. We will focus on studying the circuit of a Philips SalonDry Compact. We find the same components in devices with variants, but the overarching principle remains the same.
The overarching principle that we encounter in most hair dryers is the following: the device's power supply is 230VAC. This power supply goes through a switch with multiple positions. The switch makes it possible to vary the speed of the fan and the temperature of the hot air exiting the device.
It's often coupled with a push-button that 'cuts' heating (absent on this model). Depending on the position of the switch, current is sent to one or several resistors. One of these is in series with a diode bridge, which powers the engine in direct current.
The motor of the model studied is powered by between 12 and 17 VDC. At this voltage, it runs at approximately 20,000 rpm. Its reference number is RS-365S.
Circuit diagram: when the switch is in position 0, no current flows.
In position 1, the R3 resistor is powered, and the current (positive half wave) goes through the D1 diode, the engine, the D4 diode, then R1. The negative half wave does not flow through. The engine runs at half throttle and the resistor heats up ~by half.
In position 2, R2 and R3 are powered. The positive half wave goes through D1, the engine, and D3. Then, the negative half wave goes through D3, the engine, and D2. The engine runs at full speed and the resistors heat up fully.
Lastly, a thermostatic contact Th° is placed in the circuit to protect the device and the user, in the event of overheating.
As an example, here is the circuit diagram of a different model. We find more or less the same components, mounted differently. They are connected to a switch with 4 positions: P0 = power off; P1 = medium speed and temperature; P2 = high speed and temperature; P3 = low speed and temperature.
In position 0, the circuit is not powered. The hair dryer is off.
In position 1, current goes through D1 which cuts a current halfwave, hence reduces the effective power. The temperature gets reduced.
The current also goes through D2, which causes the same effect on the engine and on R3. The engine runs at medium throttle. R3 acts both as a divider bridge to power the engine, and as a heating element.
In position 2, the current goes directly to diodes, R1 and R2. They fully heat up. Similarly, the engine runs at max speed.
In position 3, the current no longer goes by R1 and R2. It only goes through the engine and R3, which still runs at full speed. Hence, R3 heats at its nominal speed.
This setup includes a capacitor and a resistor connected in parallel to the mains input as a noise filter, as well as two coils connected in series with the motor for the same reason. There is also a thermostatic safety switch, Th°.
Check the continuity of the power cord, wire by wire, between the mains socket and the switch. The cord is often cut at the plug or at the entry to the handle. To do this, you will need a multimeter. The procedure is shown in this video (continuity test: from 7 mins)r a comment.
It happens that the switch is faulty. If this is the case, you will need to determine if the problem is mechanical (e.g., a broken contact strip) or electrical (e.g., carbonized contacts). In any case, the repair will be difficult because you will have to open the switch to identify the source of the fault.
The motor may also be faulty. This happens if hair or dust has accumulated on its shaft and caused it to seize. To be sure, you must measure the supply voltage at its terminals with a multimeter. You must be very careful when taking this measurement while it is live.
There is 230V present inside the device. It is therefore prudent to use test clips to take the measurement safely. You should find a voltage at the motor terminals of about ten volts depending on the model and the position of the switch (+ or - hot)
As we have seen, the heating element is composed of several nichrome heating resistors. They are wound around a cone-shaped insulating support. It is possible that one of these resistors has been "mechanically" cut.
You can measure their various values with a multimeter after identifying the position of the terminals for each resistor. You should find a value of a few tens of ohms. Depending on the model, experience shows that it will be difficult to repair one or more of them without damaging the insulation or the other nearby components.
The thermal safety switch may also be the cause. In the same way, it can be measured to check for continuity. The switch should be closed. It should only open above a temperature of approximately 100°C.
A frequent failure is caused by the diode circuit which rectifies the current to power the motor with direct current. If the motor does not turn or if it only turns at low speed, it is highly probable that one (or more, depending on the case) diode is at fault. A multimeter is also useful for verifying this.
There you go! After having studied the functionalities in the first two guides on hair dryers, and then the various sub-assemblies that compose them, we have just reviewed the main causes of failure for this device.
We hope this has allowed you to learn more about your device and thus be capable of repairing it yourself.
If you liked it (or not!), don't hesitate to leave us a comment. And if you are in the area of the ’Atelier Soudé, come see us. We organize co-repair workshops, popularization sessions, and many other things....
