2021 Hyundai Veloster Spark Plug Replacement
  1. 2021 Hyundai Veloster Spark Plug Replacement, Spark Plug: step 1, image 1 of 3 2021 Hyundai Veloster Spark Plug Replacement, Spark Plug: step 1, image 2 of 3 2021 Hyundai Veloster Spark Plug Replacement, Spark Plug: step 1, image 3 of 3
    • Pull the hood latch inside your vehicle.
    Ask FixBot
  2. 2021 Hyundai Veloster Spark Plug Replacement: step 2, image 1 of 3 2021 Hyundai Veloster Spark Plug Replacement: step 2, image 2 of 3 2021 Hyundai Veloster Spark Plug Replacement: step 2, image 3 of 3
    • Open the hood and use the hood stick to prop it up securely.
    Ask FixBot
  3. 2021 Hyundai Veloster Spark Plug Replacement: step 3, image 1 of 1
    • Use a 10 mm socket wrench to remove the bolt from the negative battery terminal.
    • Disconnecting the battery ensures safety during the replacement procedure.
    • Once disconnected, securely position the negative battery terminal away from any metal surfaces to prevent accidental reconnection.
    Ask FixBot
  4. 2021 Hyundai Veloster Spark Plug Replacement: step 4, image 1 of 3 2021 Hyundai Veloster Spark Plug Replacement: step 4, image 2 of 3 2021 Hyundai Veloster Spark Plug Replacement: step 4, image 3 of 3
    • Carefully detach the engine cover with your hands and set it aside.
    Ask FixBot
  5. 2021 Hyundai Veloster Spark Plug Replacement: step 5, image 1 of 3 2021 Hyundai Veloster Spark Plug Replacement: step 5, image 2 of 3 2021 Hyundai Veloster Spark Plug Replacement: step 5, image 3 of 3
    • Identify the spark plugs on top of the engine.
    • Remove the bolts securing the spark plugs using a 10 mm socket, extension, and wrench.
    • Gently pull out the spark plug wires.
    • Exercise care when pulling out the spark plug wires to prevent dislodging any dirt or contaminants that may fall into the engine.
    Ask FixBot
  6. 2021 Hyundai Veloster Spark Plug Replacement: step 6, image 1 of 3 2021 Hyundai Veloster Spark Plug Replacement: step 6, image 2 of 3 2021 Hyundai Veloster Spark Plug Replacement: step 6, image 3 of 3
    • Utilize a spark plug socket, extension, and wrench to carefully remove all four spark plugs.
    Ask FixBot
  7. 2021 Hyundai Veloster Spark Plug Replacement: step 7, image 1 of 1
    • Verify the proper factory gap on the new spark plugs using a Spark Plug Gap Gauge.
    • Gap range: .022mm-.028mm
    Ask FixBot
  8. 2021 Hyundai Veloster Spark Plug Replacement: step 8, image 1 of 1
    • Place a new spark plug into the spark plug socket.
    • Torque each spark plug to 18 ft-lbs.
    Ask FixBot
Mehrio
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 51
All Time: 1,056
