2020 Toyota Sienna Key Fob Battery Replacement
  1. 2020 Toyota Sienna Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 3 2020 Toyota Sienna Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 3 2020 Toyota Sienna Key Fob Battery Replacement, Key Fob Battery: step 1, image 3 of 3
    • Position the battery on its side where the "Push" button is.
    • Click down on the "Push" button.
    • Pull out the physical key at the top of the fob on the same side as the "Push" button is located.
  2. 2020 Toyota Sienna Key Fob Battery Replacement: step 2, image 1 of 3 2020 Toyota Sienna Key Fob Battery Replacement: step 2, image 2 of 3 2020 Toyota Sienna Key Fob Battery Replacement: step 2, image 3 of 3
    • Place the tip of a spudger in the slotted area and twist to pry the fob open.
    • Separate the two sides of the fob carefully.
  3. 2020 Toyota Sienna Key Fob Battery Replacement: step 3, image 1 of 3 2020 Toyota Sienna Key Fob Battery Replacement: step 3, image 2 of 3 2020 Toyota Sienna Key Fob Battery Replacement: step 3, image 3 of 3
    • Lay out the two sides of the fob with the interior of the fob facing you.
    • Remove the battery from the key fob.
    • Carefully insert the new battery in the battery placeholder.
  4. 2020 Toyota Sienna Key Fob Battery Replacement: step 4, image 1 of 2 2020 Toyota Sienna Key Fob Battery Replacement: step 4, image 2 of 2
    • Grab the other side of the key fob and make sure they're aligned with each other before snapping them back together.
    • Carefully close them together.
    • You should hear a click once closed.
  5. 2020 Toyota Sienna Key Fob Battery Replacement: step 5, image 1 of 2 2020 Toyota Sienna Key Fob Battery Replacement: step 5, image 2 of 2
    • Grab the physical key and insert it back into its place.
    • Now the battery has been replaced and you are good to go!
Finish Line
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 56
All Time: 1,041
