2019 Mazda CX-5 Spark Plug Replacement
    1. 2019 Mazda CX-5 Spark Plug Replacement, Remove Engine Cover: step 1, image 1 of 2 2019 Mazda CX-5 Spark Plug Replacement, Remove Engine Cover: step 1, image 2 of 2
      • Remove the engine cover by firmly pulling upwards to release from mounting grommets and set aside.
      Ask FixBot
    2. 2019 Mazda CX-5 Spark Plug Replacement, Disconnect Ignition Coils: step 2, image 1 of 1
      • Press the locking tab down and pull each ignition coil connector straight back to disconnect from ignition coil.
      • Do not pull on ignition coil connector cable.
      Ask FixBot
    3. 2019 Mazda CX-5 Spark Plug Replacement, Remove Ignition Coils: step 3, image 1 of 3 2019 Mazda CX-5 Spark Plug Replacement, Remove Ignition Coils: step 3, image 2 of 3 2019 Mazda CX-5 Spark Plug Replacement, Remove Ignition Coils: step 3, image 3 of 3
      • Remove the bolt securing each ignition coil using an 8mm socket, then pull the coil straight upward to remove it from the spark plug well. Set aside.
      Ask FixBot
    4. 2019 Mazda CX-5 Spark Plug Replacement: step 4, image 1 of 3 2019 Mazda CX-5 Spark Plug Replacement: step 4, image 2 of 3 2019 Mazda CX-5 Spark Plug Replacement: step 4, image 3 of 3
      • Remove spark plugs by using a 14mm spark plug socket, extension and ratchet wrench, turning counterclockwise.
      • Check spark plugs for signs of fouling and any other irregular wear indicators.
      Ask FixBot
    5. 2019 Mazda CX-5 Spark Plug Replacement, Install New Spark Plugs: step 5, image 1 of 2 2019 Mazda CX-5 Spark Plug Replacement, Install New Spark Plugs: step 5, image 2 of 2
      • Ensure spark plug gap is within specification (0.044mm) on replacement plugs. Use spark plug gauge to verify. Caution: do not contact iridium tips with gauges or plyers, may cause damage.
      • Thread each new spark plug clockwise into the cylinder head by hand to avoid cross-threading.
      • Torque to specification: Between 12 to 14 lb-ft
      Ask FixBot
Neven Pavlovic
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 42
Past 30 Days: 207
All Time: 1,196
