2019 Chevrolet Colorado Windshield Wiper Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
32
Past 30 Days:
104
All Time:
5,119
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will cover how to replace the windshield wipers in a 2019 Chevrolet Colorado.
The guide covers how to take off the windshield wipers as well as how to reinstall the wipers. This is a truck so some may need to use a step stool in order to reach the wipers depending on how high your truck is raised.
This is a fairly easy task that only requires your hands to disassemble and reassemble.
Before you start this guide make sure your truck is off, parked, and on a flat surface just to ensure that you are completing this guide in a safe manner.
    1. 2019 Chevrolet Colorado Windshield Wiper Replacement, Windshield Wiper: step 1, image 1 of 1
      • Identify where the buttons are on the windshield wipers are.
      • Once the buttons are identified make note of where they are located on both wipers because of the different sizes they are slightly different on each.
      Ask FixBot
    2. 2019 Chevrolet Colorado Windshield Wiper Replacement: step 2, image 1 of 2 2019 Chevrolet Colorado Windshield Wiper Replacement: step 2, image 2 of 2
      • Lift the drive side wiper up so that it is no longer touching the windshield.
      • This allows you to have better access to the wipers.
      Ask FixBot
    3. 2019 Chevrolet Colorado Windshield Wiper Replacement: step 3, image 1 of 2 2019 Chevrolet Colorado Windshield Wiper Replacement: step 3, image 2 of 2
      • Disconnect the blade on the driver side by pushing the small button down in order to release the wiper.
      Ask FixBot
    4. 2019 Chevrolet Colorado Windshield Wiper Replacement: step 4, image 1 of 3 2019 Chevrolet Colorado Windshield Wiper Replacement: step 4, image 2 of 3 2019 Chevrolet Colorado Windshield Wiper Replacement: step 4, image 3 of 3
      • Slowly slide the wiper off of the wiper arm by pulling it back and away from the windshield.
      • The wiper arm is like a hook so make sure that you completely unhook the metal piece from the wiper blade.
      • Follow the direction of the arrows.
      Ask FixBot
    5. 2019 Chevrolet Colorado Windshield Wiper Replacement: step 5, image 1 of 3 2019 Chevrolet Colorado Windshield Wiper Replacement: step 5, image 2 of 3 2019 Chevrolet Colorado Windshield Wiper Replacement: step 5, image 3 of 3
      • Repeat steps 1-4 on the passenger side wiper.
      Ask FixBot
    6. 2019 Chevrolet Colorado Windshield Wiper Replacement: step 6, image 1 of 2 2019 Chevrolet Colorado Windshield Wiper Replacement: step 6, image 2 of 2
      • Grab the 22" wiper blade and position it on the wiper arm so that it is hooked into places as well as flush with the arm.
      Ask FixBot
    7. 2019 Chevrolet Colorado Windshield Wiper Replacement: step 7, image 1 of 3 2019 Chevrolet Colorado Windshield Wiper Replacement: step 7, image 2 of 3 2019 Chevrolet Colorado Windshield Wiper Replacement: step 7, image 3 of 3
      • Pull the wiper blade down with your right hand and slowly push with your left onto the wiper arm until you hear it snap back into place.
      • Make sure that the wiper is securely fastened and that it cannot be removed without pushing the button.
      • Follow the direction of the arrow.
      Ask FixBot
    8. 2019 Chevrolet Colorado Windshield Wiper Replacement: step 8, image 1 of 3 2019 Chevrolet Colorado Windshield Wiper Replacement: step 8, image 2 of 3 2019 Chevrolet Colorado Windshield Wiper Replacement: step 8, image 3 of 3
      • Repeat steps 6 and 7 on the passenger side wiper. Make sure you are using the 18" wiper for the passenger side replacement.
      Ask FixBot
to reassemble your device, follow these instructions in reverse order
1 Guide Comment
Xq se enciende el testigo de 4x4 automático de una colorado modelo 2020
Andres Gil - Reply Share
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 104
All Time: 5,119
