2018 Toyota Highlander Key Fob Battery Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
8
Past 7 Days:
47
Past 30 Days:
174
All Time:
1,118
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to replace the battery in a 2018 Toyota Highlander Key Fob, which is the standard remote used for locking, unlocking, and starting many Toyota Highlander vehicles. Some versions of this remote are also called the Toyota Smart Key or the Toyota Remote Keyless Entry Fob.
The key fob battery powers the internal transmitter that communicates with the vehicle. When the battery begins to fail, the key fob may only work at very close range, respond inconsistently, or stop unlocking the car entirely. Some vehicles will also show a warning message that the key battery is low. Replacing the battery restores normal signal strength and prevents the key fob from failing unexpectedly.
This repair replaces the CR2032 lithium coin cell located inside the fob. Coin cell batteries are small and convenient, but they can be hazardous if punctured, bent, or exposed to metal tools. Avoid squeezing the battery with pliers and keep it away from small children and pets, since swallowed coin batteries can cause serious injury. Old batteries should be recycled properly instead of being thrown in the trash.
Before beginning, make sure the issue is actually caused by a weak battery. Problems caused by water exposure, impact damage, or worn buttons will not be fixed by replacing the battery. If your vehicle uses a push button start system, a dead key fob battery can also prevent the car from detecting the key, so replacing the battery as soon as symptoms appear is important.
This repair does not require any special skills or electronic experience. The key fob does not need to be reprogrammed after the battery is replaced, and the procedure can be completed safely with basic tools.
Tools
    1. 2018 Toyota Highlander Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 2 2018 Toyota Highlander Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 2
      • Insert a spudger into the gap in the casing.
      • Gently twist or wiggle the tool to separate the two halves of the casing.
      Ask FixBot
    2. 2018 Toyota Highlander Key Fob Battery Replacement: step 2, image 1 of 3 2018 Toyota Highlander Key Fob Battery Replacement: step 2, image 2 of 3 2018 Toyota Highlander Key Fob Battery Replacement: step 2, image 3 of 3
      • Remove the battery casing from the key fob.
      Ask FixBot
    3. 2018 Toyota Highlander Key Fob Battery Replacement: step 3, image 1 of 3 2018 Toyota Highlander Key Fob Battery Replacement: step 3, image 2 of 3 2018 Toyota Highlander Key Fob Battery Replacement: step 3, image 3 of 3
      • Use a spudger to gently lift the battery casing.
      • Slide the pointed end of a spudger tip under the circular battery and carefully lift it out.
      Ask FixBot
    4. 2018 Toyota Highlander Key Fob Battery Replacement: step 4, image 1 of 3 2018 Toyota Highlander Key Fob Battery Replacement: step 4, image 2 of 3 2018 Toyota Highlander Key Fob Battery Replacement: step 4, image 3 of 3
      • Carefully remove the motherboard connected to the battery.
      • Hold the edges of the board to avoid touching any electronic components.
      • Set the motherboard aside on a clean, static-free surface.
      Ask FixBot
    5. 2018 Toyota Highlander Key Fob Battery Replacement: step 5, image 1 of 3 2018 Toyota Highlander Key Fob Battery Replacement: step 5, image 2 of 3 2018 Toyota Highlander Key Fob Battery Replacement: step 5, image 3 of 3
      • Remove the old battery. If needed, gently open the metal holder securing it in place.
      • Use your finger to slide the battery out of the compartment.
      • If the battery is difficult to remove, use a pair of tweezers to lift it out carefully.
      Ask FixBot
    6. 2018 Toyota Highlander Key Fob Battery Replacement: step 6, image 1 of 3 2018 Toyota Highlander Key Fob Battery Replacement: step 6, image 2 of 3 2018 Toyota Highlander Key Fob Battery Replacement: step 6, image 3 of 3
      • Insert the new battery into the holder. If needed, close the metal clip to secure it in place.
      • Use a pair of tweezers if necessary to help position the battery.
      • Ensure the battery slides smoothly back into place.
      Ask FixBot
    7. 2018 Toyota Highlander Key Fob Battery Replacement: step 7, image 1 of 3 2018 Toyota Highlander Key Fob Battery Replacement: step 7, image 2 of 3 2018 Toyota Highlander Key Fob Battery Replacement: step 7, image 3 of 3
      • Snap the battery casing back together, ensuring both halves align properly.
      Ask FixBot
    8. 2018 Toyota Highlander Key Fob Battery Replacement: step 8, image 1 of 2 2018 Toyota Highlander Key Fob Battery Replacement: step 8, image 2 of 2
      • Press the battery and internal components firmly into the key fob casing.
      • Ensure the casing halves are properly aligned before closing.
      • Snap the key fob back together — you should hear a click when it’s securely closed.
      Ask FixBot
    9. 2018 Toyota Highlander Key Fob Battery Replacement: step 9, image 1 of 2 2018 Toyota Highlander Key Fob Battery Replacement: step 9, image 2 of 2
      • Make sure the buttons are properly aligned before snapping the key fob casing closed.
      • Ensure the casing halves are correctly aligned to avoid pinching any internal parts.
      • Snap the casing back together until you hear a click.
      • Check that all buttons are in place and respond smoothly when pressed.
      Ask FixBot
Finish Line
Brandon Choi
169 Reputation
1 Guide authored
UC Davis, Team 1-1, Morris Fall 2025 Member of UC Davis, Team 1-1, Morris Fall 2025
UCD-MORRIS-F25S1G1
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 47
Past 30 Days: 174
All Time: 1,118
