Introduction
Use this guide to replace a dead battery in your 2017 Chevrolet Camaro key fob. The key fob uses a single CR2032 3-volt lithium coin battery to send a wireless signal to your car.
If your remote's range is weak, has a delayed response, or your dashboard shows a "Key Fob Battery Low" warning, it is time to swap the battery.
Press and hold the silver release button on the side of the key fob.
While continuing to hold the button, pull the chrome top loop outward to slide the emergency key blade out of the transmitter body.
Insert the tip of the emergency key blade or a plastic opening tool underneath the edge of the circular CR2032 battery.
Gently pry upward to pop the battery out of its retaining clips.
Slide a new CR2032 3V lithium battery into the slot at a slight angle, pressing down until it clicks into place. Line up the front and back plastic covers of the key fob and press them firmly together until they snap shut.
