2016 Toyota Camry Key Fob Battery Replacement
    1. 2016 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 3 2016 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 3 2016 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: step 1, image 3 of 3
      • Take a coin and wedge it between both halves of the key fob where the keychain notch is. Push against the indent until the fob begins to lift open.
      • Take care not to lose the buttons, as they may fall out.
      Ask FixBot
    2. 2016 Toyota Camry Key Fob Battery Replacement: step 2, image 1 of 3 2016 Toyota Camry Key Fob Battery Replacement: step 2, image 2 of 3 2016 Toyota Camry Key Fob Battery Replacement: step 2, image 3 of 3
      • Look for the notch where it says “use coin to open." Push against the indent with your coin to separate the pieces.
      • Remove the middle console.
      Ask FixBot
    3. 2016 Toyota Camry Key Fob Battery Replacement: step 3, image 1 of 2 2016 Toyota Camry Key Fob Battery Replacement: step 3, image 2 of 2
      • Use your fingernail to pry around the battery until it pops out.
      • When inserting the new battery, make sure that the positive side is facing up.
      Ask FixBot
3 other people completed this guide.
1 Guide Comment
Thanks and nicely done. The small plastic clips that hold the battery can be tricky.
Michael Lynn - Reply Share
Past 24 Hours: 9
Past 7 Days: 57
Past 30 Days: 313
All Time: 20,843
