2016 Nissan Altima Key Fob Battery Replacement
  1. 2016 Nissan Altima Key Fob Battery Replacement, Battery: step 1, image 1 of 3 2016 Nissan Altima Key Fob Battery Replacement, Battery: step 1, image 2 of 3 2016 Nissan Altima Key Fob Battery Replacement, Battery: step 1, image 3 of 3
    • Slide the little switch up on the back of the key. While doing so, remove the physical key that is stored inside the fob by pulling away.
    Ask FixBot
  2. 2016 Nissan Altima Key Fob Battery Replacement: step 2, image 1 of 1
    • Insert a flathead screwdriver or prying tool into the small notch located at the bottom of the key fob.
    • Carefully rotate the flathead counterclockwise to pry apart the two halves of the fob.
    Ask FixBot
  3. 2016 Nissan Altima Key Fob Battery Replacement: step 3, image 1 of 1
    • Pry out the battery with a flathead to avoid skin contact with electrical components.
    • Make sure to avoid touching the motherboard.
    Ask FixBot
  4. 2016 Nissan Altima Key Fob Battery Replacement: step 4, image 1 of 1
    • Now carefully place the new battery onto the silver platter.
    • Keep in mind positive side of the battery will be facing downward, while negative side will be facing towards you.
    Ask FixBot
  5. 2016 Nissan Altima Key Fob Battery Replacement: step 5, image 1 of 1
    • Line up the parts in order to secure the key.
    • Press down until the case makes a "click" sound.
    Ask FixBot
  6. 2016 Nissan Altima Key Fob Battery Replacement: step 6, image 1 of 1
    • Finally, insert the physical key back into the fob to complete your replacement.
    Ask FixBot
4 other people completed this guide.
Giovanni Avalos
241 Reputation
1 Guide authored
1 Guide Comment
Great job , thanks . Sent wife info and believe it she figured it out, thanks.
Erik - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 110
All Time: 7,983
