2015 Nissan Altima Mass Air Flow Sensor Replacement
    1. 2015 Nissan Altima Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: step 1, image 1 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: step 1, image 2 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement, Mass Air Flow Sensor: step 1, image 3 of 3
      • Open the driver's side door where the hood release is located.
      Ask FixBot
    2. 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 2, image 1 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 2, image 2 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 2, image 3 of 3
      • Connect a scanner by clicking it into the obd2 port.
      Ask FixBot
    3. 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 3, image 1 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 3, image 2 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 3, image 3 of 3
      • Run the code through the scanner.
      Ask FixBot
    4. 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 4, image 1 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 4, image 2 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 4, image 3 of 3
      • Open up the hood latch.
      • Locate front hood holder and lift it up for safety.
      Ask FixBot
    5. 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 5, image 1 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 5, image 2 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 5, image 3 of 3
      • Locate the battery and a positive and negative terminal.
      • The Positive terminal.
      • The Negative terminal.
      • Be careful risk of electrical shock
      Ask FixBot
    6. 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 6, image 1 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 6, image 2 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 6, image 3 of 3
      • Unscrew the positive terminal with a 10mm wrench by turning it counterclockwise.
      Ask FixBot
    7. 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 7, image 1 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 7, image 2 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 7, image 3 of 3
      • Unscrew the negative terminal with a 10mm wrench by turning it counterclockwise.
      Ask FixBot
    8. 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 8, image 1 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 8, image 2 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 8, image 3 of 3
      • Unplug the mass air flow sensor by pushing in the pull tabs and pulling upwards.
      Ask FixBot
    9. 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 9, image 1 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 9, image 2 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 9, image 3 of 3
      • Remove the screws with a Phillips #1 screwdriver by turning them counterclockwise.
      Ask FixBot
    10. 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 10, image 1 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 10, image 2 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 10, image 3 of 3
      • Remove the old sensor by pulling it off and replace with a new one.
      Ask FixBot
    11. 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 11, image 1 of 2 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 11, image 2 of 2
      • Screw back on the screws with a Phillips #1 screwdriver by turning them clockwise.
      Ask FixBot
    12. 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 12, image 1 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 12, image 2 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 12, image 3 of 3
      • Click the sensor in place.
      • Plug in the battery by following steps 6 and 7 in reverse order.
      Ask FixBot
    13. 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 13, image 1 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 13, image 2 of 3 2015 Nissan Altima Mass Air Flow Sensor Replacement: step 13, image 3 of 3
      • Run the scanner again and make sure no check engine light is on and no trouble codes appear.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 99
All Time: 2,046
