2015 Ford Mustang Key Fob Battery Replacement
Views: 20K
View statistics:
Past 24 Hours:
8
Past 7 Days:
78
Past 30 Days:
250
All Time:
20,417
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your 2015 Ford Mustang key fob has lost its ability to start your car, your battery has likely died.
When your key fob battery dies, you lose the ability to start your car, unlock and lock your doors, as well as automatically start your car on those cold mornings. Your car will alert you when your battery is running low, so you should have ample time to get to the store and purchase a replacement battery.
Parts
Tools
    1. 2015 Ford Mustang Key Fob Battery Replacement, Key Fob Battery: step 1, image 1 of 3 2015 Ford Mustang Key Fob Battery Replacement, Key Fob Battery: step 1, image 2 of 3 2015 Ford Mustang Key Fob Battery Replacement, Key Fob Battery: step 1, image 3 of 3
      • Press down on the button to open the plastic notch.
      • Remove the back plastic case of the key fob.
      Ask FixBot
    2. 2015 Ford Mustang Key Fob Battery Replacement: step 2, image 1 of 3 2015 Ford Mustang Key Fob Battery Replacement: step 2, image 2 of 3 2015 Ford Mustang Key Fob Battery Replacement: step 2, image 3 of 3
      • Insert a prying tool or a quarter into the groove in the middle of the key fob.
      • Apply pressure to lift up the middle section.
      Ask FixBot
    3. 2015 Ford Mustang Key Fob Battery Replacement: step 3, image 1 of 2 2015 Ford Mustang Key Fob Battery Replacement: step 3, image 2 of 2
      • Lift up and remove the middle piece.
      Ask FixBot
    4. 2015 Ford Mustang Key Fob Battery Replacement: step 4, image 1 of 2 2015 Ford Mustang Key Fob Battery Replacement: step 4, image 2 of 2
      • Lift up on the batteries to remove them.
      • When inserting new batteries, follow the instructions on the white tag.
      • Do not remove the white tag.
      Ask FixBot
    5. 2015 Ford Mustang Key Fob Battery Replacement: step 5, image 1 of 1
      • After you have replaced the batteries it should look like this.
      Ask FixBot
3 other people completed this guide.
Lauren Underwood
184 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 78
Past 30 Days: 250
All Time: 20,417
