2014 Toyota Highlander Key Fob Battery Replacement
  1. 2014 Toyota Highlander Key Fob Battery Replacement, Battery: step 1, image 1 of 3 2014 Toyota Highlander Key Fob Battery Replacement, Battery: step 1, image 2 of 3 2014 Toyota Highlander Key Fob Battery Replacement, Battery: step 1, image 3 of 3
    • Remove the key by pressing the button on the side.
    • Make sure the red alarm button is face-up so that the button you need to press is on the left side of the plastic layer.
    Ask FixBot
  2. 2014 Toyota Highlander Key Fob Battery Replacement: step 2, image 1 of 2 2014 Toyota Highlander Key Fob Battery Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Insert tweezers into the notch where the key was.
    • You can use any kind of tweezer you have at home as long as it fits into the notch.
    Ask FixBot
  3. 2014 Toyota Highlander Key Fob Battery Replacement: step 3, image 1 of 1
    • Apply a small amount of pressure to the tweezer, so you can use them to pop the plastic layer open.
    Ask FixBot
  4. 2014 Toyota Highlander Key Fob Battery Replacement: step 4, image 1 of 2 2014 Toyota Highlander Key Fob Battery Replacement: step 4, image 2 of 2
    • Check the front and back of the green circuit to locate the battery.
    Ask FixBot
  5. 2014 Toyota Highlander Key Fob Battery Replacement: step 5, image 1 of 3 2014 Toyota Highlander Key Fob Battery Replacement: step 5, image 2 of 3 2014 Toyota Highlander Key Fob Battery Replacement: step 5, image 3 of 3
    • Using the pair of tweezers, remove the battery from the device.
    Ask FixBot
Muhamad Razeq
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 84
All Time: 5,491
