2013 Lexus IS250 Front Dome Light Replacement
  1. 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: step 1, image 1 of 2 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: step 1, image 2 of 2
    • Open the glasses compartment located near the front dome light. This is usually a straightforward latch or button release.
    Ask FixBot
  2. 2013 Lexus IS250 Front Dome Light Replacement: step 2, image 1 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 2, image 2 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 2, image 3 of 3
    • Locate two housings inisde the compartment and gently pry them open using a flathead screwdriver. Take care not to damage the surrounding plastic.
    Ask FixBot
  3. 2013 Lexus IS250 Front Dome Light Replacement: step 3, image 1 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 3, image 2 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 3, image 3 of 3
    • Utilize a star screwdriver to remove the screws holding the front dome light in place. Ensure a steady hand to prevent any accidental dropping of screws.
    Ask FixBot
  4. 2013 Lexus IS250 Front Dome Light Replacement: step 4, image 1 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 4, image 2 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 4, image 3 of 3
    • With both hands wiggle both sides of the dome. Apply a bit of force at the top to release it from its position. Be cautious to not break the plastic clips securing it.
    Ask FixBot
  5. 2013 Lexus IS250 Front Dome Light Replacement: step 5, image 1 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 5, image 2 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 5, image 3 of 3
    • Inside, youll find two bulbs on both ends. Twist them to unlock and carefully remove.
    Ask FixBot
  6. 2013 Lexus IS250 Front Dome Light Replacement: step 6, image 1 of 2 2013 Lexus IS250 Front Dome Light Replacement: step 6, image 2 of 2
    • Carefully remove bulb. Recommended to use gloves as it can be difficult to get a grip.
    Ask FixBot
  7. 2013 Lexus IS250 Front Dome Light Replacement: step 7, image 1 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 7, image 2 of 3 2013 Lexus IS250 Front Dome Light Replacement: step 7, image 3 of 3
    • Replace these bulbs with LED alternatives, inserting them and securing by twisting.
    Ask FixBot
  8. 2013 Lexus IS250 Front Dome Light Replacement: step 8, image 1 of 1
    • Confirm that the bulbs are functioning by checking if the lights turn on. If not double check the alignment of the bulbs to ensure proper contact.
    • Carefully place the dome back into its original position. Ensure it aligns correctly with the plastic tips. Apply gentle pressure until it clicks back into place.
    Ask FixBot
Christian
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 44
All Time: 914
