2013 Kia Forte Wheel Replacement
Views: 9.6K
View statistics:
Past 24 Hours:
8
Past 7 Days:
28
Past 30 Days:
103
All Time:
9,625
Comments: 2
2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Easy
Introduction
Go to step 1 ↓
Within this How-To guide you will learn how to change the tire of a 2013 Kia Forte EX. This task is quick and simple, requiring minimal effort. These instructions apply to Kia Forte models 2013 to present.
    1. 2013 Kia Forte Wheel Replacement, Wheel: step 1, image 1 of 1
      • Open trunk. Most 2013 models do not have a trunk button on the remote. In order to open trunk, hold down unlock button.
      Ask FixBot
    2. 2013 Kia Forte Wheel Replacement: step 2, image 1 of 3 2013 Kia Forte Wheel Replacement: step 2, image 2 of 3 2013 Kia Forte Wheel Replacement: step 2, image 3 of 3
      • Remove the three trunk mats, shown in order.
      • The bottom, hard plastic mat serves as a surface to lay on, if need, whilst changing tire.
      Ask FixBot
    3. 2013 Kia Forte Wheel Replacement: step 3, image 1 of 1
      • Spare tire and tools needed to change tire are located under the trunk mats.
      • The jack and lug wrench are placed in a styrofoam container on top of the spare tire.
      Ask FixBot
    4. 2013 Kia Forte Wheel Replacement: step 4, image 1 of 2 2013 Kia Forte Wheel Replacement: step 4, image 2 of 2
      • Turning counterclockwise, unscrew and remove plastic place holder in center of spare tire.
      Ask FixBot
    5. 2013 Kia Forte Wheel Replacement: step 5, image 1 of 2 2013 Kia Forte Wheel Replacement: step 5, image 2 of 2
      • Loosen lug nuts turning counterclockwise, one turn each.
      • Do not loosen lug nuts by circling the tire. Loosen them first in the 1, 3 and 5 positions (shown in red circles; the '1' position pointing north). After loosening the 1, 3 and 5 positions, loosen 2 and 4.
      • Do not completely remove ANY lug nuts until tire is raised from ground.
      Ask FixBot
    6. 2013 Kia Forte Wheel Replacement: step 6, image 1 of 2 2013 Kia Forte Wheel Replacement: step 6, image 2 of 2
      • Place jack under jack plate, under appropriate tire.
      • Jack plates are welded to frame with two tabs and raised dots to indicate index with jack.
      Ask FixBot
    7. 2013 Kia Forte Wheel Replacement: step 7, image 1 of 3 2013 Kia Forte Wheel Replacement: step 7, image 2 of 3 2013 Kia Forte Wheel Replacement: step 7, image 3 of 3
      • Insert jack hook into loop on jack.
      • Insert end of jack hook into lug wrench.
      • To raise vehicle turn the lug wrench, attached to jack hook, clockwise. Turn until tire is one inch (approximately 30mm) off ground.
      Ask FixBot
    8. 2013 Kia Forte Wheel Replacement: step 8, image 1 of 3 2013 Kia Forte Wheel Replacement: step 8, image 2 of 3 2013 Kia Forte Wheel Replacement: step 8, image 3 of 3
      • Once tire is elevated, remove lug nuts by hand.
      • Be aware that the tire will shift as lug nuts are removed.
      • After removing lug nuts, carefully take tire off of frame.
      Ask FixBot
    9. 2013 Kia Forte Wheel Replacement: step 9, image 1 of 2 2013 Kia Forte Wheel Replacement: step 9, image 2 of 2
      • Place spare tire onto frame.
      • Hand tighten lug nuts (the 1, 3 and 5 positions first) until secure.
      Ask FixBot
    10. 2013 Kia Forte Wheel Replacement: step 10, image 1 of 2 2013 Kia Forte Wheel Replacement: step 10, image 2 of 2
      • Lower vehicle, turning jack counterclockwise, until tire touches ground.
      • Tighten lug nuts (again, beginning with the 1, 3 and 5 positions) with lug wrench until secure.
      Ask FixBot
    11. 2013 Kia Forte Wheel Replacement: step 11, image 1 of 1
      • Congratulations, your tire is changed!
      • NOTE: obey the speed limitations of your spare tire. Exceeding the recommended speed is dangerous and can damage the spare.
      Ask FixBot
Finish Line
5 other people completed this guide.
Kaleb
239 Reputation
1 Guide authored
2 Guide Comments
Anyone have anything to share about this vehicle?
Experience, maintenance and repair logs or experiences of note?
Thanks, ive just received this car and have been told its a good one. Have no prior experience with kias though.
2.0 cyclical engine.
RxMode - Reply Share
Je veux voir comment fait calage de kia Sportage
Italien Frais de yakro - Reply Share
Past 24 Hours: 8
Past 7 Days: 28
Past 30 Days: 103
All Time: 9,625
