2013 GMC Terrain Headlight Bulb Replacement
    1. 2013 GMC Terrain Headlight Bulb Replacement, Headlight Bulb: step 1, image 1 of 1
      • Identify which headlight is out.
      Ask FixBot
    2. 2013 GMC Terrain Headlight Bulb Replacement: step 2, image 1 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 2, image 2 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 2, image 3 of 3
      • Turn the wheels toward the opposite side of the broken headlight.
      • Go to the Front fender on the side with the broken headlight and find the cover on the fender liner.
      Ask FixBot
    3. 2013 GMC Terrain Headlight Bulb Replacement: step 3, image 1 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 3, image 2 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 3, image 3 of 3
      • Use a T15 Torx screwdriver to remove the screw.
      • Turn the cover counterclockwise to remove it.
      Ask FixBot
    4. 2013 GMC Terrain Headlight Bulb Replacement: step 4, image 1 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 4, image 2 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 4, image 3 of 3
      • Reach into the hole to find the round cap to the bulb.
      • Turn it counterclockwise to expose the socket holding the bulb.
      Ask FixBot
    5. 2013 GMC Terrain Headlight Bulb Replacement: step 5, image 1 of 2 2013 GMC Terrain Headlight Bulb Replacement: step 5, image 2 of 2
      • Twist the socket counterclockwise and pull it out to expose the bulb.
      Ask FixBot
    6. 2013 GMC Terrain Headlight Bulb Replacement: step 6, image 1 of 2 2013 GMC Terrain Headlight Bulb Replacement: step 6, image 2 of 2
      • Unclip the old bulb from the socket.
      Ask FixBot
    7. 2013 GMC Terrain Headlight Bulb Replacement: step 7, image 1 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 7, image 2 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 7, image 3 of 3
      • Grab your new bulb.
      • Make sure not to touch the actual bulb because the oils from your skin can cause it to burn out.
      • Plug it back into the socket and twist it clockwise in the hole.
      Ask FixBot
    8. 2013 GMC Terrain Headlight Bulb Replacement: step 8, image 1 of 1
      • Place the headlight cover back on and turn it clockwise to secure it.
      Ask FixBot
    9. 2013 GMC Terrain Headlight Bulb Replacement: step 9, image 1 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 9, image 2 of 3 2013 GMC Terrain Headlight Bulb Replacement: step 9, image 3 of 3
      • Place the inner fender cover over the hole.
      • Twist the cover clockwise until it's tight
      • Screw in the Torx screw until it is tight.
      Ask FixBot
    10. 2013 GMC Terrain Headlight Bulb Replacement: step 10, image 1 of 1
      • Finally, your headlights should both work.
      Ask FixBot
Now your headlights should work perfectly.
Rafaj27
205 Reputation
1 Guide authored
CSU Los Angeles, Team 4-70, Harris Fall 2024 Member of CSU Los Angeles, Team 4-70, Harris Fall 2024
CSULA-HARRIS-F24S4G70
2 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 138
All Time: 1,474
