2013 Ford Focus SE Stereo Replacement
    1. 2013 Ford Focus SE  Stereo Replacement, Stereo: step 1, image 1 of 3 2013 Ford Focus SE  Stereo Replacement, Stereo: step 1, image 2 of 3 2013 Ford Focus SE  Stereo Replacement, Stereo: step 1, image 3 of 3
      • Unlock the car using the unlock button on the key fob or inserting the key into the door.
      • Open the car door.
      • The stereo panel is attached to the center dashboard.
      Ask FixBot
    2. 2013 Ford Focus SE  Stereo Replacement: step 2, image 1 of 3 2013 Ford Focus SE  Stereo Replacement: step 2, image 2 of 3 2013 Ford Focus SE  Stereo Replacement: step 2, image 3 of 3
      • Use the T20 Torx screwdriver to remove the two 19 mm torx screws under the lip of the stereo panel.
      • Set aside these screws for reassembly.
      Ask FixBot
    3. 2013 Ford Focus SE  Stereo Replacement: step 3, image 1 of 3 2013 Ford Focus SE  Stereo Replacement: step 3, image 2 of 3 2013 Ford Focus SE  Stereo Replacement: step 3, image 3 of 3
      • Carefully lift the panel up and out.
      • There is a wire attached to the back of panel.
      • Unplug the stereo connector from the panel and set aside the panel.
      • There are two Torx screw's attached to the stereo box.
      Ask FixBot
    4. 2013 Ford Focus SE  Stereo Replacement: step 4, image 1 of 3 2013 Ford Focus SE  Stereo Replacement: step 4, image 2 of 3 2013 Ford Focus SE  Stereo Replacement: step 4, image 3 of 3
      • Use the Torx T20 screwdriver to unscrew the top left and top right 19 mm screws.
      • Slowly remove the stereo box from the screw connectors.
      Ask FixBot
    5. 2013 Ford Focus SE  Stereo Replacement: step 5, image 1 of 3 2013 Ford Focus SE  Stereo Replacement: step 5, image 2 of 3 2013 Ford Focus SE  Stereo Replacement: step 5, image 3 of 3
      • Once the stereo box is removed from connectors, there will be 3 cords attached to the box.
      • The yellow wire will require some force to open because it serves as the power connector for the stereo.
      • Carefully push down on the clamp to disconnect the yellow wire on the far left of the box.
      • Push down on the clamps in the middle to remove the middle wire.
      • Push down on the clamps in the middle to remove the far right wire.
      Ask FixBot
    6. 2013 Ford Focus SE  Stereo Replacement: step 6, image 1 of 2 2013 Ford Focus SE  Stereo Replacement: step 6, image 2 of 2
      • Once the wires are disconnected, safely remove the stereo box.
      • In order to proceed to the next step, reassemble the new stereo by following the steps in reverse order.
      Ask FixBot
    7. 2013 Ford Focus SE  Stereo Replacement: step 7, image 1 of 3 2013 Ford Focus SE  Stereo Replacement: step 7, image 2 of 3 2013 Ford Focus SE  Stereo Replacement: step 7, image 3 of 3
      • It is safe to turn the car on once the stereo has been reinstalled.
      • Press the center stereo button to turn the stereo on.
      • Press the menu button.
      • Press the OK button on SYNC-Media.
      Ask FixBot
    8. 2013 Ford Focus SE  Stereo Replacement: step 8, image 1 of 2 2013 Ford Focus SE  Stereo Replacement: step 8, image 2 of 2
      • Use the arrow buttons on the stereo panel to navigate to the " Bluetooth Device" page.
      • Press OK on the " Bluetooth Device" page.
      • Navigate to the "Add Bluetooth Device" page using the arrow buttons and press OK.
      • Follow on screen prompt to connect to Bluetooth.
      • Refer to the introduction for a guide on how to connect to SYNC-Phone.
      Ask FixBot
5 other people completed this guide.
4 Guide Comments
Great instructions, but the first step for how to remove the cover over the two torques screws is missing. Would really like to know how to remove that cover.
Todd - Reply Share
Why have the instructions been edited, yet my simple, specific question has not been addressed?
Todd - Reply Share
Todd, you just have to stick a small flat head in any of the 4 inserts and mine popped right out.
Alex Hedbany - Reply Share
My question is, does the replacement radio need any type of dealership reprogramming or is it just plug and play?
Past 24 Hours: 9
Past 7 Days: 53
Past 30 Days: 256
All Time: 18,235
