2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement
  1. 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement, Front Turn Signal Bulb: step 1, image 1 of 1
    • Lift the hood of the car and keep it in place using the hood prop.
    Ask FixBot
  2. 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 2, image 1 of 3 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 2, image 2 of 3 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 2, image 3 of 3
    • Remove the screws from the headlight assembly by using a pair of slip-joint pliers.
    Ask FixBot
  3. 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 3, image 1 of 3 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 3, image 2 of 3 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 3, image 3 of 3
    • Pull out the headlight assembly slightly to make more room for your hands.
    • If necessary, locate the back cap of the low beam socket and twist it counterclockwise to unscrew it.
    • This creates extra room for your hands.
    Ask FixBot
  4. 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 4, image 1 of 2 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 4, image 2 of 2
    • Locate the turn signal bulb socket within the headlight assembly.
    Ask FixBot
  5. 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 5, image 1 of 3 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 5, image 2 of 3 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 5, image 3 of 3
    • To remove the turn signal bulb socket from the headlight assembly, twist it counterclockwise. Once it is completely unscrewed, pull the turn signal bulb socket out of the headlight assembly.
    Ask FixBot
  6. 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 6, image 1 of 2 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 6, image 2 of 2
    • Press down on the old turn signal bulb and twist it counterclockwise to remove it from the socket.
    Ask FixBot
  7. 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 7, image 1 of 3 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 7, image 2 of 3 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 7, image 3 of 3
    • Using latex (or similar) gloves, pick up the new turn signal bulb and align the pins on the bulb with the grooves in the socket.
    • Using gloves is important because the oils on your fingers can create hot spots on the new turn signal bulb, reducing its lifetime.
    • Press down on the new turn signal bulb and twist it clockwise to secure it within the socket.
    Ask FixBot
  8. 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 8, image 1 of 3 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 8, image 2 of 3 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 8, image 3 of 3
    • Re-install the turn signal socket into the headlight assembly by twisting it clockwise until it stops turning.
    • If necessary, re-install the low beam socket back cap by twisting it clockwise until it stops turning.
    Ask FixBot
  9. 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 9, image 1 of 1
    • Push the headlight assembly back into place.
    Ask FixBot
  10. 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 10, image 1 of 3 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 10, image 2 of 3 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 10, image 3 of 3
    • Re-install the screws that hold the headlight assembly in place by using a pair of slip-joint pliers, starting with the back screw.
    Ask FixBot
  11. 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 11, image 1 of 2 2012 Hyundai Santa Fe Front Turn Signal Bulb Replacement: step 11, image 2 of 2
    • Remove the hood prop and close the hood.
    Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 77
All Time: 1,539
