2012 Ford Fusion Headlight Replacement
    1. 2012 Ford Fusion Headlight Replacement, Headlight: step 1, image 1 of 1
      • Locate the hood latch and pull it to open
      Ask FixBot
    2. 2012 Ford Fusion Headlight Replacement: step 2, image 1 of 3 2012 Ford Fusion Headlight Replacement: step 2, image 2 of 3 2012 Ford Fusion Headlight Replacement: step 2, image 3 of 3
      • The front hood will open and be caught by a saftey latch. Run fingers under the hood and push the latch to the left to open the hood completely
      Ask FixBot
    3. 2012 Ford Fusion Headlight Replacement: step 3, image 1 of 2 2012 Ford Fusion Headlight Replacement: step 3, image 2 of 2
      • Hold up the hood with the hood support rod
      Ask FixBot
    4. 2012 Ford Fusion Headlight Replacement: step 4, image 1 of 2 2012 Ford Fusion Headlight Replacement: step 4, image 2 of 2
      • Remove negative terminal from the battery using a 10mm socket. Remove the bolt that is holding the negative terminal and pull terminal off the battery.
      Ask FixBot
    5. 2012 Ford Fusion Headlight Replacement: step 5, image 1 of 2 2012 Ford Fusion Headlight Replacement: step 5, image 2 of 2
      • Locate the headlight bulb in the front of the car under the hood and twist off the cap covering the headlight bulb
      Ask FixBot
    6. 2012 Ford Fusion Headlight Replacement: step 6, image 1 of 2 2012 Ford Fusion Headlight Replacement: step 6, image 2 of 2
      • twist the housing to the light bulb and pull it out
      Ask FixBot
    7. 2012 Ford Fusion Headlight Replacement: step 7, image 1 of 2 2012 Ford Fusion Headlight Replacement: step 7, image 2 of 2
      • unclip the light bulb from the housing latch and replace light bulb
      Ask FixBot
To reassemble your headlight, follow these instructions in reverse order.
4 other people completed this guide.
6 Guide Comments
What about the left side?
destroyer2040 - Reply Share
So this was completely useless. You only showed the one semi easy to reach bulb whereas the rest look like the front of the car needs to be disassembled to reach. Why even post this useless junk?
Joe - Reply Share
I agree with both previous comments. your efforts are INCOMPLETE.
What about the left side(PASSENGER  SIDE THAT IS)
You only showed the one semi easy to reach(DRIVER’S SIDE, THAT IS)
Al Moghtader - Reply Share
Yea this guide is incomplete and not helpful.
John Fisher - Reply Share
what years do the head lite assy match with on 2012 ford fusion sle
gordon r bissell - Reply Share
Past 24 Hours: 1
Past 7 Days: 31
Past 30 Days: 120
All Time: 16,500
