2012 Ford Fusion Brake Light Replacement
    1. 2012 Ford Fusion Brake Light Replacement, Brake Light: step 1, image 1 of 2 2012 Ford Fusion Brake Light Replacement, Brake Light: step 1, image 2 of 2
      • Locate the button that opens the trunk
      Ask FixBot
    2. 2012 Ford Fusion Brake Light Replacement: step 2, image 1 of 2 2012 Ford Fusion Brake Light Replacement: step 2, image 2 of 2
      • Locate plastic fasteners and remove with door panel remove tool/flathead by prying them off
      Ask FixBot
    3. 2012 Ford Fusion Brake Light Replacement: step 3, image 1 of 2 2012 Ford Fusion Brake Light Replacement: step 3, image 2 of 2
      • Pull tab and remove trunk cover
      Ask FixBot
    4. 2012 Ford Fusion Brake Light Replacement: step 4, image 1 of 2 2012 Ford Fusion Brake Light Replacement: step 4, image 2 of 2
      • On the inside of the trunk remove the side panel to locate the brake light bulb
      Ask FixBot
    5. 2012 Ford Fusion Brake Light Replacement: step 5, image 1 of 1
      • Pull the Brown housing that holds the brake light
      Ask FixBot
    6. 2012 Ford Fusion Brake Light Replacement: step 6, image 1 of 2 2012 Ford Fusion Brake Light Replacement: step 6, image 2 of 2
      • Remove brake light from housing by pulling it out gently and replace with new bulb
      Ask FixBot
To reassemble your taillight bulb, follow these instructions in reverse order.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 76
All Time: 7,051
