2012 Chevy Equinox Tail Light Bulb Replacement
  1. 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: step 1, image 1 of 3 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: step 1, image 2 of 3 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: step 1, image 3 of 3
    • Open the trunk of your car.
    Ask FixBot
  2. 2012 Chevy Equinox Tail Light Bulb Replacement: step 2, image 1 of 3 2012 Chevy Equinox Tail Light Bulb Replacement: step 2, image 2 of 3 2012 Chevy Equinox Tail Light Bulb Replacement: step 2, image 3 of 3
    • Remove the two plastic caps by placing a spudger in the bottom opening and gently prying upward.
    Ask FixBot
  3. 2012 Chevy Equinox Tail Light Bulb Replacement: step 3, image 1 of 3 2012 Chevy Equinox Tail Light Bulb Replacement: step 3, image 2 of 3 2012 Chevy Equinox Tail Light Bulb Replacement: step 3, image 3 of 3
    • Remove the two 6 mm Phillips #2 screws located underneath each of the plastic caps by twisting counterclockwise.
    Ask FixBot
  4. 2012 Chevy Equinox Tail Light Bulb Replacement: step 4, image 1 of 3 2012 Chevy Equinox Tail Light Bulb Replacement: step 4, image 2 of 3 2012 Chevy Equinox Tail Light Bulb Replacement: step 4, image 3 of 3
    • Hold the latch down firmly and pull the tail light cover off the vehicle.
    • You may have to apply a back and forth force to remove the cover.
    Ask FixBot
  5. 2012 Chevy Equinox Tail Light Bulb Replacement: step 5, image 1 of 3 2012 Chevy Equinox Tail Light Bulb Replacement: step 5, image 2 of 3 2012 Chevy Equinox Tail Light Bulb Replacement: step 5, image 3 of 3
    • Remove the light bulb socket from the vehicle by gently twisting and pulling it out of the tail light cover.
    Ask FixBot
  6. 2012 Chevy Equinox Tail Light Bulb Replacement: step 6, image 1 of 3 2012 Chevy Equinox Tail Light Bulb Replacement: step 6, image 2 of 3 2012 Chevy Equinox Tail Light Bulb Replacement: step 6, image 3 of 3
    • Twist the light bulb counterclockwise and pull to remove it from the socket.
    Ask FixBot
  7. 2012 Chevy Equinox Tail Light Bulb Replacement: step 7, image 1 of 3 2012 Chevy Equinox Tail Light Bulb Replacement: step 7, image 2 of 3 2012 Chevy Equinox Tail Light Bulb Replacement: step 7, image 3 of 3
    • Insert the new light bulb by gently pushing the light bulb into the socket and twisting clockwise.
    • When reassembling, make sure to align the tail light cover up to the back of the vehicle before pushing the cover back on.
    Ask FixBot
Kelly Dixon
145 Reputation
1 Guide authored
Texas Tech, Team S9-G2, Cowan Fall 2020 Member of Texas Tech, Team S9-G2, Cowan Fall 2020
TTU-COWAN-F20S9G2
1 Member
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 41
All Time: 2,979
