2011 Honda Pilot Overhead Lightbulb and Switch Replacement
  1. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement, Overhead Lightbulb and Switch: step 1, image 1 of 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement, Overhead Lightbulb and Switch: step 1, image 2 of 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement, Overhead Lightbulb and Switch: step 1, image 3 of 3
    • Use a plastic pry tool to detach the light cover.
    • Be careful not to pry too hard, otherwise you risk breaking the cover.
  2. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 2, image 1 of 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 2, image 2 of 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 2, image 3 of 3
    • Use the pry tool to the light and attach the new one inside of the clamps that hold the bulb.
    • Repeat the same process for the left side bulb.
  3. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 3, image 1 of 2 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 3, image 2 of 2
    • Remove the screws inside of the unit using a Phillips #00 screwdriver.
  4. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 4, image 1 of 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 4, image 2 of 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 4, image 3 of 3
    • Open the sunglasses case.
    • Use a Phillips #00 screwdriver to remove the screws.
    • Keep track of the screws. The front ones are silver, while the black ones inside the sunglasses case are black.
  5. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 5, image 1 of 1
    • After the screws come undone, this is what the unit should look like.
  6. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 6, image 1 of 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 6, image 2 of 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 6, image 3 of 3
    • Press down on the four cable clamps to detach them.
    • Do not use the wires to pull them out. You may risk damaging the cables connecting to the unit.
  7. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 7, image 1 of 1
    • After detaching all cables, the unit should look like this and come right off.
  8. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 8, image 1 of 2 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 8, image 2 of 2
    • Insert a plastic pry tool inside this little slot. Once you do, flick up to release this middle part from the unit.
  9. 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 9, image 1 of 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 9, image 2 of 3 2011 Honda Pilot Overhead Lightbulb and Switch Replacement: step 9, image 3 of 3
    • Insert a prying tool into the button switch. Then push out to flick out the button.
    • Once the button has fallen out, insert the new switches by sliding them back where the old ones were.
Nicholas Sisneros
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 31
All Time: 519
