2011 Ford Fiesta Headlight Replacement
    1. 2011 Ford Fiesta Headlight Replacement, Indicator Bulb: step 1, image 1 of 1
      • Park the car where you have room to work.
      • Check that the hand brake is on and the engine is off.
      • Wait for the car to cool down before opening the hood. The hot air from the engine may damage the eyes and cause burns.
      • Ensure that the car has rested for at least 30 minutes.
      Ask FixBot
    2. 2011 Ford Fiesta Headlight Replacement: step 2, image 1 of 3 2011 Ford Fiesta Headlight Replacement: step 2, image 2 of 3 2011 Ford Fiesta Headlight Replacement: step 2, image 3 of 3
      • Pull the hood release under the driver's dashboard towards you.
      Ask FixBot
    3. 2011 Ford Fiesta Headlight Replacement: step 3, image 1 of 3 2011 Ford Fiesta Headlight Replacement: step 3, image 2 of 3 2011 Ford Fiesta Headlight Replacement: step 3, image 3 of 3
      • Make sure there is space to insert fingers. If not, repeat step 2.
      • Push the yellow hood release to the left to open the hood.
      Ask FixBot
    4. 2011 Ford Fiesta Headlight Replacement: step 4, image 1 of 2 2011 Ford Fiesta Headlight Replacement: step 4, image 2 of 2
      • Lift the hood with one hand and place the strut upright in the correct position.
      • Place strut in the hole to the left of the hood.
      Ask FixBot
    5. 2011 Ford Fiesta Headlight Replacement: step 5, image 1 of 3 2011 Ford Fiesta Headlight Replacement: step 5, image 2 of 3 2011 Ford Fiesta Headlight Replacement: step 5, image 3 of 3
      • Use a flathead screwdriver to loosen the lower retained screw.
      • Collect the screws and store them somewhere safe.
      Ask FixBot
    6. 2011 Ford Fiesta Headlight Replacement: step 6, image 1 of 2 2011 Ford Fiesta Headlight Replacement: step 6, image 2 of 2
      • Remove the upper retained screw.
      • Store the screw in a safe place.
      Ask FixBot
    7. 2011 Ford Fiesta Headlight Replacement: step 7, image 1 of 3 2011 Ford Fiesta Headlight Replacement: step 7, image 2 of 3 2011 Ford Fiesta Headlight Replacement: step 7, image 3 of 3
      • Carefully remove the headlight.
      • The headlight is attached to three electrical connectors.
      • Gently pull up and towards your body.
      • Set the headlight to the side.
      Ask FixBot
    8. 2011 Ford Fiesta Headlight Replacement: step 8, image 1 of 3 2011 Ford Fiesta Headlight Replacement: step 8, image 2 of 3 2011 Ford Fiesta Headlight Replacement: step 8, image 3 of 3
      • Press both ends of the bulb container to remove the electrical connector from the bulb container.
      Ask FixBot
    9. 2011 Ford Fiesta Headlight Replacement: step 9, image 1 of 3 2011 Ford Fiesta Headlight Replacement: step 9, image 2 of 3 2011 Ford Fiesta Headlight Replacement: step 9, image 3 of 3
      • Pull out the bulb from the headlight.
      • Press both ends of the electrical connector to separate from the bulb container.
      Ask FixBot
    10. 2011 Ford Fiesta Headlight Replacement: step 10, image 1 of 1
      • Make sure you do not hold the glass surface with your bare hands. The bulb may malfunction from the sweat in your hands.
      • Hold the black part of the bulb.
      • The bulb might break, so be sure to wear gloves and protective glasses.
      Ask FixBot
Phillip Kataswa
208 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 61
All Time: 9,645
