2010 Toyota Corolla Headlight Replacement
    1. 2010 Toyota Corolla Headlight Replacement, Headlight Bulb: step 1, image 1 of 3 2010 Toyota Corolla Headlight Replacement, Headlight Bulb: step 1, image 2 of 3 2010 Toyota Corolla Headlight Replacement, Headlight Bulb: step 1, image 3 of 3
      • Find the handle to open the Bonnet. It will be located at the bottom left-hand side of the driver's seat.
      • Pull the handle towards yourself and you will see the bonnet pop up a small bit.
      Ask FixBot
    2. 2010 Toyota Corolla Headlight Replacement: step 2, image 1 of 3 2010 Toyota Corolla Headlight Replacement: step 2, image 2 of 3 2010 Toyota Corolla Headlight Replacement: step 2, image 3 of 3
      • Move the handle to the left in order to release the hood completely.
      • Locate the black stick and insert it in the bonnet hole.
      Ask FixBot
    3. 2010 Toyota Corolla Headlight Replacement: step 3, image 1 of 3 2010 Toyota Corolla Headlight Replacement: step 3, image 2 of 3 2010 Toyota Corolla Headlight Replacement: step 3, image 3 of 3
      • On the left, upper side of the hood, you can locate the bulb
      • Twist it halfway counter-clockwise and pull it out.
      Ask FixBot
    4. 2010 Toyota Corolla Headlight Replacement: step 4, image 1 of 3 2010 Toyota Corolla Headlight Replacement: step 4, image 2 of 3 2010 Toyota Corolla Headlight Replacement: step 4, image 3 of 3
      • Push the hook down to detach the bulb from the wire.
      Ask FixBot
    5. 2010 Toyota Corolla Headlight Replacement: step 5, image 1 of 3 2010 Toyota Corolla Headlight Replacement: step 5, image 2 of 3 2010 Toyota Corolla Headlight Replacement: step 5, image 3 of 3
      • Replace it with a new bulb and turn it clockwise to have it fixed permanently.
      • If the bulb is not turned clockwise, the bulb will come off and become loose again.
      Ask FixBot
    6. 2010 Toyota Corolla Headlight Replacement: step 6, image 1 of 3 2010 Toyota Corolla Headlight Replacement: step 6, image 2 of 3 2010 Toyota Corolla Headlight Replacement: step 6, image 3 of 3
      • Turn on the lights to make sure both headlights are working :)
      Ask FixBot
4 other people completed this guide.
Shahbaz Khan
223 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 34
Past 30 Days: 126
All Time: 5,056
