2010 Jeep Liberty Headlight Bulb Replacement
    1. 2010 Jeep Liberty Headlight Bulb Replacement, Headlight Bulb: step 1, image 1 of 1
      • Pop the hood of your vehicle by pulling the lever near the bottom of the driver's side door.
      • Slide your hands under the unlatched hood to find the second lever. Push this lever to the right and lift the hood.
      • Be sure to use the hood prop to keep the hood from falling while you're underneath it.
      Ask FixBot
    2. 2010 Jeep Liberty Headlight Bulb Replacement: step 2, image 1 of 3 2010 Jeep Liberty Headlight Bulb Replacement: step 2, image 2 of 3 2010 Jeep Liberty Headlight Bulb Replacement: step 2, image 3 of 3
      • Identify the bulb socket, located behind the headlight.
      • Rotate the base of the bulb counter-clockwise to remove it from the socket.
      • Remove the bulb from the green base by pulling the two apart.
      Ask FixBot
    3. 2010 Jeep Liberty Headlight Bulb Replacement: step 3, image 1 of 3 2010 Jeep Liberty Headlight Bulb Replacement: step 3, image 2 of 3 2010 Jeep Liberty Headlight Bulb Replacement: step 3, image 3 of 3
      • Insert the new bulb into the green base.
      • Be sure not to touch the glass with your fingers. If you do, wipe the bulb down with a soft cloth and some rubbing alcohol. Oils left behind from your fingers can shorten the life of the bulb.
      • Rotate clockwise to lock the bulb assembly into the socket.
      Ask FixBot
    4. 2010 Jeep Liberty Headlight Bulb Replacement: step 4, image 1 of 1
      • Turn on headlights to ensure the new bulb is working properly.
      • You will want to check that your headlights are aligned on both sides. Adjust as needed.
      Ask FixBot
Congratulations! You have a shiny new headlight.
9 other people completed this guide.
Ryan Griffin
269 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 68
All Time: 10,520
