2010 Chevrolet Aveo Headlight Replacement
    1. 2010 Chevrolet Aveo Headlight Replacement, Headlight: step 1, image 1 of 1
      • Pull the hood release lever underneath the steering wheel to release hood lock.
      Ask FixBot
    2. 2010 Chevrolet Aveo Headlight Replacement: step 2, image 1 of 2 2010 Chevrolet Aveo Headlight Replacement: step 2, image 2 of 2
      • Release the lever under the hood and lift it up to release the hood completely. Simultaneously lift the hood and prop it up with the hood prop securing it in an open position.
      Ask FixBot
    3. 2010 Chevrolet Aveo Headlight Replacement: step 3, image 1 of 2 2010 Chevrolet Aveo Headlight Replacement: step 3, image 2 of 2
      • Disconnect the headlight wire connector.
      Ask FixBot
    4. 2010 Chevrolet Aveo Headlight Replacement: step 4, image 1 of 3 2010 Chevrolet Aveo Headlight Replacement: step 4, image 2 of 3 2010 Chevrolet Aveo Headlight Replacement: step 4, image 3 of 3
      • Use 10 mm socket to remove three bolts securing headlight housing.
      • Keep the bolts and washer together for reinstallation of headlight housing.
      • Carefully pull the headlight housing away from the vehicle until you can easily access the rear housing.
      Ask FixBot
    5. 2010 Chevrolet Aveo Headlight Replacement: step 5, image 1 of 3 2010 Chevrolet Aveo Headlight Replacement: step 5, image 2 of 3 2010 Chevrolet Aveo Headlight Replacement: step 5, image 3 of 3
      • Remove the outer gasket and set it aside for reinstallation.
      • Disconnect the clip from the headlight mount.
      • It should stay attached by the Philips #1 screw however this may become loose from daily use and the clip may become disconnected.
      • In this instance simply reinstall the clip as shown and tighten the screw with the Philips #1 screwdriver.
      • Remove the headlight so the housing is empty and ready for replacement.
      Ask FixBot
    6. 2010 Chevrolet Aveo Headlight Replacement: step 6, image 1 of 1
      • This is the how new headlight will be assembled in the vehicle (this process will happen in steps, this is simply a reference to the final form).
      Ask FixBot
    7. 2010 Chevrolet Aveo Headlight Replacement: step 7, image 1 of 2 2010 Chevrolet Aveo Headlight Replacement: step 7, image 2 of 2
      • Start the new headlight installation by placing the headlight mount into the headlight housing and secure it with the clip by pinching the ends together and hooking it under the edges of the housing.
      Ask FixBot
    8. 2010 Chevrolet Aveo Headlight Replacement: step 8, image 1 of 3 2010 Chevrolet Aveo Headlight Replacement: step 8, image 2 of 3 2010 Chevrolet Aveo Headlight Replacement: step 8, image 3 of 3
      • Slide the outer gasket over the headlight mount ensuring the "top" is properly oriented.
      • Line up the grooves on the new headlight with the headlight harness.
      • Insert the headlight and rotate it to lock it in place.
      Ask FixBot
    9. 2010 Chevrolet Aveo Headlight Replacement: step 9, image 1 of 3 2010 Chevrolet Aveo Headlight Replacement: step 9, image 2 of 3 2010 Chevrolet Aveo Headlight Replacement: step 9, image 3 of 3
      • Reinstall the headlight housing by setting the housing back into place and lining up the bolt holes.
      • Replace the three bolts using a 10mm socket and ratchet.
      • Reattach the headlight connector.
      Ask FixBot
Repeat steps 3 through 9 for other headlight. Ensure proper working order upon completion.
6 other people completed this guide.
Ryan
313 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 135
All Time: 4,100
