2009 Honda Fit Brake Light Bulb Replacement
  1. 2009 Honda Fit Brake Light Bulb Replacement, Brake Light Bulb: step 1, image 1 of 1
    • Open your trunk to access the brake light panel.
    Ask FixBot
  2. 2009 Honda Fit Brake Light Bulb Replacement: step 2, image 1 of 3 2009 Honda Fit Brake Light Bulb Replacement: step 2, image 2 of 3 2009 Honda Fit Brake Light Bulb Replacement: step 2, image 3 of 3
    • Use a trim removal tool or your key to pry the panel and gain access to the brake light.
    Ask FixBot
  3. 2009 Honda Fit Brake Light Bulb Replacement: step 3, image 1 of 3 2009 Honda Fit Brake Light Bulb Replacement: step 3, image 2 of 3 2009 Honda Fit Brake Light Bulb Replacement: step 3, image 3 of 3
    • Rotate the brake light socket clockwise until it unlocks.
    • Pull out the brake light socket.
    • Make sure you are replacing the bottom bulb(brake light) and not the top bulb(tail light).
    Ask FixBot
  4. 2009 Honda Fit Brake Light Bulb Replacement: step 4, image 1 of 2 2009 Honda Fit Brake Light Bulb Replacement: step 4, image 2 of 2
    • Pull out the old bulb from brake light socket and insert new bulb.
    • The old bulb can be identified with its dark burnt look.
    • Wear a nitrile glove or something similar to avoid getting oils from your fingers on the glass bulb. The oils and salt on your hands can reduce the life of the bulb and cause it to burn out more quickly.
    Ask FixBot
  5. 2009 Honda Fit Brake Light Bulb Replacement: step 5, image 1 of 2 2009 Honda Fit Brake Light Bulb Replacement: step 5, image 2 of 2
    • Insert brake light socket with the new bulb into the housing compartment.
    • Similar to the removal, you have to rotate the socket into a locked position.
    Ask FixBot
  6. 2009 Honda Fit Brake Light Bulb Replacement: step 6, image 1 of 3 2009 Honda Fit Brake Light Bulb Replacement: step 6, image 2 of 3 2009 Honda Fit Brake Light Bulb Replacement: step 6, image 3 of 3
    • After reassembly, have someone test the brake light so you can see if it works or not.
    • If no one is available to help, reverse towards a wall and park. Press on the brake and look at your side mirrors to check if they light up.
    Ask FixBot
3 other people completed this guide.
mchail
196 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 121
All Time: 2,729
