2009 Honda Civic Window Regulator Replacement
  1. 2009 Honda Civic Window Regulator Replacement, Window Regulator: step 1, image 1 of 3 2009 Honda Civic Window Regulator Replacement, Window Regulator: step 1, image 2 of 3 2009 Honda Civic Window Regulator Replacement, Window Regulator: step 1, image 3 of 3
    • Park the vehicle on a level surface and turn off the ignition.
    Ask FixBot
  2. 2009 Honda Civic Window Regulator Replacement: step 2, image 1 of 3 2009 Honda Civic Window Regulator Replacement: step 2, image 2 of 3 2009 Honda Civic Window Regulator Replacement: step 2, image 3 of 3
    • Remove the Phillips screw located behind the door handle.
    Ask FixBot
  3. 2009 Honda Civic Window Regulator Replacement: step 3, image 1 of 2 2009 Honda Civic Window Regulator Replacement: step 3, image 2 of 2
    • Place a prying tool in the small crevice at the centre of the window controller and pry upwards.
    Ask FixBot
  4. 2009 Honda Civic Window Regulator Replacement: step 4, image 1 of 2 2009 Honda Civic Window Regulator Replacement: step 4, image 2 of 2
    • Disconnect the electrical connectors attached to the panel by pressing onto the tab.
    Ask FixBot
  5. 2009 Honda Civic Window Regulator Replacement: step 5, image 1 of 3 2009 Honda Civic Window Regulator Replacement: step 5, image 2 of 3 2009 Honda Civic Window Regulator Replacement: step 5, image 3 of 3
    • Use a prying tool to pry off the door panel.
    Ask FixBot
  6. 2009 Honda Civic Window Regulator Replacement: step 6, image 1 of 2 2009 Honda Civic Window Regulator Replacement: step 6, image 2 of 2
    • Push downwards on the holder and pull the wire towards yourself.
    Ask FixBot
  7. 2009 Honda Civic Window Regulator Replacement: step 7, image 1 of 2 2009 Honda Civic Window Regulator Replacement: step 7, image 2 of 2
    • Use a prying tool to remove the two black plugs on the left-hand side and right-hand side of the plastic liner.
    Ask FixBot
  8. 2009 Honda Civic Window Regulator Replacement: step 8, image 1 of 2 2009 Honda Civic Window Regulator Replacement: step 8, image 2 of 2
    • Remove the connector by pushing onto the tab using a prying tool.
    Ask FixBot
  9. 2009 Honda Civic Window Regulator Replacement: step 9, image 1 of 2 2009 Honda Civic Window Regulator Replacement: step 9, image 2 of 2
    • Gently remove the plastic liner.
    Ask FixBot
  10. 2009 Honda Civic Window Regulator Replacement: step 10, image 1 of 2 2009 Honda Civic Window Regulator Replacement: step 10, image 2 of 2
    • Use a wrench to remove the two bolts located at the left-hand side and right-hand side.
    Ask FixBot
  11. 2009 Honda Civic Window Regulator Replacement: step 11, image 1 of 3 2009 Honda Civic Window Regulator Replacement: step 11, image 2 of 3 2009 Honda Civic Window Regulator Replacement: step 11, image 3 of 3
    • Use the wrench to unscrew the first bolt located at the top of the door in a counterclockwise motion.
    • Use the wrench to unscrew the second bolt located at the bottom of the door in a counterclockwise motion.
    Ask FixBot
  12. 2009 Honda Civic Window Regulator Replacement: step 12, image 1 of 2 2009 Honda Civic Window Regulator Replacement: step 12, image 2 of 2
    • After removing all four bolts, use your hands to remove the window regulator.
    Ask FixBot
5 other people completed this guide.
Usman Khan
478 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 66
All Time: 1,685
