2008 Toyota Prius Cabin Filter Replacement
  1. 2008 Toyota Prius Cabin Filter Replacement, Cabin filter: step 1, image 1 of 2 2008 Toyota Prius Cabin Filter Replacement, Cabin filter: step 1, image 2 of 2
    • Make sure your glove compartment is empty.
    Ask FixBot
  2. 2008 Toyota Prius Cabin Filter Replacement: step 2, image 1 of 1
    • Remove your glove compartment by pushing in both sides of the frame of the compartment.
    Ask FixBot
  3. 2008 Toyota Prius Cabin Filter Replacement: step 3, image 1 of 1
    • Disconnect the hydraulic strut.
    Ask FixBot
  4. 2008 Toyota Prius Cabin Filter Replacement: step 4, image 1 of 2 2008 Toyota Prius Cabin Filter Replacement: step 4, image 2 of 2
    • Once the hydraulic press is disconnected, you can pull it straight up, and the glove box will come out.
    • This will expose the cabin filter.
    Ask FixBot
  5. 2008 Toyota Prius Cabin Filter Replacement: step 5, image 1 of 1
    • Push both sides of the cabin filter together, and pull it straight out.
    Ask FixBot
  6. 2008 Toyota Prius Cabin Filter Replacement: step 6, image 1 of 1
    • Remove the filter from the filter holder. Then place your new filter in the filter holder.
    Ask FixBot
Hopefully, this guide provided a transparent, precise set of instructions to help you replace your cabin filter; once the cabin filter is replaced to assemble the glovebox back together, follow these instructions in reverse order.
3 other people completed this guide.
Alex Hernandez
205 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 83
All Time: 2,010
