2008 Honda Pilot Tail Light Assembly Replacement
  1. 2008 Honda Pilot Tail Light Assembly Replacement, Tail Light Assembly: step 1, image 1 of 2 2008 Honda Pilot Tail Light Assembly Replacement, Tail Light Assembly: step 1, image 2 of 2
    • Open the vehicle's trunk to see the two bolts holding the assembly to the body.
    • Remove the two 8 mm bolts using either a Phillips head screwdriver or socket wrench.
    • Save the bolts! They will be needed for installing the new assembly.
    Ask FixBot
  2. 2008 Honda Pilot Tail Light Assembly Replacement: step 2, image 1 of 2 2008 Honda Pilot Tail Light Assembly Replacement: step 2, image 2 of 2
    • Place both hands on the assembly and pull it away from the vehicle.
    • There are two clips on the back of the assembly that are connecting it to the vehicle. They will disengage if the assembly is pulled with adequate force.
    • If the clips won't disengage try using a rocking motion while pulling on the assembly.
    Ask FixBot
  3. 2008 Honda Pilot Tail Light Assembly Replacement: step 3, image 1 of 3 2008 Honda Pilot Tail Light Assembly Replacement: step 3, image 2 of 3 2008 Honda Pilot Tail Light Assembly Replacement: step 3, image 3 of 3
    • Unlock the three light sockets connected to the assembly by twisting them counter clockwise.
    • Pull the light sockets out of the assembly.
    Ask FixBot
  4. 2008 Honda Pilot Tail Light Assembly Replacement: step 4, image 1 of 3 2008 Honda Pilot Tail Light Assembly Replacement: step 4, image 2 of 3 2008 Honda Pilot Tail Light Assembly Replacement: step 4, image 3 of 3
    • Set the old assembly aside.
    • Take the new assembly, and put the light bulb sockets into their corresponding holes.
    • Twist each socket clockwise to lock them into place.
    Ask FixBot
  5. 2008 Honda Pilot Tail Light Assembly Replacement: step 5, image 1 of 3 2008 Honda Pilot Tail Light Assembly Replacement: step 5, image 2 of 3 2008 Honda Pilot Tail Light Assembly Replacement: step 5, image 3 of 3
    • Line the clips on the back of assembly up with their holes, and push the assembly into place.
    • Take the bolts from Step 2 and place them into the holes on the new assembly. Twist them clockwise until secure.
    Ask FixBot
  6. 2008 Honda Pilot Tail Light Assembly Replacement: step 6, image 1 of 1
    • Congratulations! You have installed a new tail light assembly on your vehicle!
    Ask FixBot
Congratulations! You have successfully completed the guide! Enjoy your new tail light assembly.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 37
All Time: 1,066
