2006 Xserve Teardown
Views: 2.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
110
All Time:
2,366
Comments: 3
3 comments on steps.
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 50 minutes
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Community-Contributed Guide
Introduction
Go to step 1 ↓
A quick step by step guide to full dissemble a 2006 Xserve Apple Server
Parts
Tools
    1. 2006 Xserve Teardown, Unplug: step 1, image 1 of 1
      • Unplug power and connections and hold power for 15s to make sure the residual power is gone
      • Careful with the fibre lines if you have a raid attached
      • Graphic card if installed
      Ask FixBot
    2. 2006 Xserve Teardown, Remove Cover: step 2, image 1 of 3 2006 Xserve Teardown, Remove Cover: step 2, image 2 of 3 2006 Xserve Teardown, Remove Cover: step 2, image 3 of 3
      • Unscrew the two thumb screws at the back.
      • Pull back on the top, then remove the top cover.
      Ask FixBot
    3. 2006 Xserve Teardown, Remove Power Modules: step 3, image 1 of 3 2006 Xserve Teardown, Remove Power Modules: step 3, image 2 of 3 2006 Xserve Teardown, Remove Power Modules: step 3, image 3 of 3
      • pull out and to the right with the black locking lever
      • Pull out module
      Ask FixBot
    4. 2006 Xserve Teardown, Remove HardDrives: step 4, image 1 of 3 2006 Xserve Teardown, Remove HardDrives: step 4, image 2 of 3 2006 Xserve Teardown, Remove HardDrives: step 4, image 3 of 3
      • Push on the caddy handles to release the handle's then pull each one out.
      Ask FixBot
    5. 2006 Xserve Teardown, Remove Airduct: step 5, image 1 of 3 2006 Xserve Teardown, Remove Airduct: step 5, image 2 of 3 2006 Xserve Teardown, Remove Airduct: step 5, image 3 of 3
      • use a #1 phillips on the 5 screws holding the Airduct in place.
      • slide up and out easily.
      • carefull with the backplane-to-logic board I/O cable
      Ask FixBot
    6. 2006 Xserve Teardown, Fan Array: step 6, image 1 of 3 2006 Xserve Teardown, Fan Array: step 6, image 2 of 3 2006 Xserve Teardown, Fan Array: step 6, image 3 of 3
      • please note these are captive thumb screws and will not come all the way out
      • To remove the fan array you need to loosen two phillips on the right and left of the array as noted in the pic's.
      • Carefull around the fan plug requires you to pull straight up after screws are lose
      Ask FixBot
    7. 2006 Xserve Teardown, Remove PCI Cards: step 7, image 1 of 3 2006 Xserve Teardown, Remove PCI Cards: step 7, image 2 of 3 2006 Xserve Teardown, Remove PCI Cards: step 7, image 3 of 3
      • Loosen the two captive screws that secure the riser bracket to the back panel.
      • pull up a little to clear the captive screws then lean back should come out easy
      • the Screws in the case act like alinement pins careful when pulling up
      • Also a good time to check the ROM battery! Replace battery only with type CR2032.
      Ask FixBot
    8. 2006 Xserve Teardown, Front Panel Board Cable: step 8, image 1 of 3 2006 Xserve Teardown, Front Panel Board Cable: step 8, image 2 of 3 2006 Xserve Teardown, Front Panel Board Cable: step 8, image 3 of 3
      • This is a delicate cable push the 2 sides together to release
      • This cable is molded to go back in only one way do not try any other orientation
      • Pop one side out then rock the connector wile pressing on the other tab for easier removal
      • The connecter is keyed for one way only
      Ask FixBot
    9. 2006 Xserve Teardown, Backplane-to-Logic Board I/O Cable: step 9, image 1 of 3 2006 Xserve Teardown, Backplane-to-Logic Board I/O Cable: step 9, image 2 of 3 2006 Xserve Teardown, Backplane-to-Logic Board I/O Cable: step 9, image 3 of 3
      • they are only press in connectors use a Spudger to pry one side, should come free after a little force
      • Carefull with the connecters as they can be damaged!
      • Note! there is adhesive on the side of the cable along the power module's side
      Ask FixBot
    10. 2006 Xserve Teardown, CD Drive Cable: step 10, image 1 of 3 2006 Xserve Teardown, CD Drive Cable: step 10, image 2 of 3 2006 Xserve Teardown, CD Drive Cable: step 10, image 3 of 3
      • lift one side of the connector gently it should pop out
      • !Note! more adhesive out lined in red!
      • Don't Use a screw driver like i did use a plastic Heavy-Duty Spudger
      Ask FixBot
    11. 2006 Xserve Teardown, Removing CD Drive: step 11, image 1 of 3 2006 Xserve Teardown, Removing CD Drive: step 11, image 2 of 3 2006 Xserve Teardown, Removing CD Drive: step 11, image 3 of 3
      • Unlock the CD locking leaver by sliding the arm to the left.
      • Push back away from bezel then lift up and out the drive.
      Ask FixBot
      • Unscrew 4 #0 Phillips screws and remove carriage
      Ask FixBot
    12. 2006 Xserve Teardown, Ram Removal: step 13, image 1 of 3 2006 Xserve Teardown, Ram Removal: step 13, image 2 of 3 2006 Xserve Teardown, Ram Removal: step 13, image 3 of 3
      • To remove open the tabs on either side of the Ram slot to remove~ repeat for all ram.
      • !note! Max Ram on a 2006 =32GB
      Ask FixBot
    13. 2006 Xserve Teardown, Raid card/ Drive Array: step 14, image 1 of 2 2006 Xserve Teardown, Raid card/ Drive Array: step 14, image 2 of 2
      • Unscrew the one thumb screw on the main part of the board
      Ask FixBot
Finish Line
6 other people completed this guide.
Attached Documents
mitch
298 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 110
All Time: 2,366
