2006 Toyota Matrix Center Brake Light Bulb Replacement
  1. 2006 Toyota Matrix Center Brake Light Bulb Replacement, Center brake light bulb: step 1, image 1 of 3 2006 Toyota Matrix Center Brake Light Bulb Replacement, Center brake light bulb: step 1, image 2 of 3 2006 Toyota Matrix Center Brake Light Bulb Replacement, Center brake light bulb: step 1, image 3 of 3
    • Open the trunk.
    • The brake light is located at the upper center of the inside of the trunk window.
    Ask FixBot
  2. 2006 Toyota Matrix Center Brake Light Bulb Replacement: step 2, image 1 of 3 2006 Toyota Matrix Center Brake Light Bulb Replacement: step 2, image 2 of 3 2006 Toyota Matrix Center Brake Light Bulb Replacement: step 2, image 3 of 3
    • Use a Phillips screwdriver to remove two screws from the brake light mount.
    • Use a flathead screwdriver to pry the brake light mount on both sides and push out the black plastic fasteners.
    • To prevent the brake light mount from falling, hold it in place while pushing out the plastic fasteners.
    Ask FixBot
  3. 2006 Toyota Matrix Center Brake Light Bulb Replacement: step 3, image 1 of 3 2006 Toyota Matrix Center Brake Light Bulb Replacement: step 3, image 2 of 3 2006 Toyota Matrix Center Brake Light Bulb Replacement: step 3, image 3 of 3
    • Hold the brake mount in place, carefully press down on the brake light cable connector, and remove it from the socket.
    Ask FixBot
  4. 2006 Toyota Matrix Center Brake Light Bulb Replacement: step 4, image 1 of 3 2006 Toyota Matrix Center Brake Light Bulb Replacement: step 4, image 2 of 3 2006 Toyota Matrix Center Brake Light Bulb Replacement: step 4, image 3 of 3
    • Unclip the red light cover from the mounting points on both the front-left and front-right sides.
    • Gently wiggle and pull out the light bulb from its location.
    Ask FixBot
  5. 2006 Toyota Matrix Center Brake Light Bulb Replacement: step 5, image 1 of 3 2006 Toyota Matrix Center Brake Light Bulb Replacement: step 5, image 2 of 3 2006 Toyota Matrix Center Brake Light Bulb Replacement: step 5, image 3 of 3
    • Insert the new light bulb, then carefully press down to secure the light bulb.
    • Insert the center clip of the red cover into the slot on the brake light mount.
    • Clip the lens front-side left and right clipping position into the mount's designated clipping locations.
    Ask FixBot
  6. 2006 Toyota Matrix Center Brake Light Bulb Replacement: step 6, image 1 of 3 2006 Toyota Matrix Center Brake Light Bulb Replacement: step 6, image 2 of 3 2006 Toyota Matrix Center Brake Light Bulb Replacement: step 6, image 3 of 3
    • Reconnect the brake light mount to the cable attachment.
    • Push the mount's black plastic fasteners into the highlighted holes.
    • Use moderate force to push in the plastic fasteners
    • Replace the two Phillips screws into the brake light mount.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Ds.1234
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 62
All Time: 451
