2006 Toyota Highlander Side View Mirror Replacement
  1. 2006 Toyota Highlander Side View Mirror Replacement, Side View Mirror: step 1, image 1 of 3 2006 Toyota Highlander Side View Mirror Replacement, Side View Mirror: step 1, image 2 of 3 2006 Toyota Highlander Side View Mirror Replacement, Side View Mirror: step 1, image 3 of 3
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
    • Pop out the master switch panel with a heavy duty spudger by sliding it in from the side.
    • Flip the master switch over to see the plug.
    • Unplug the master switch panel by firmly pushing down the notch and pulling it out.
    • This may require some force.
    Ask FixBot
  2. 2006 Toyota Highlander Side View Mirror Replacement: step 2, image 1 of 3 2006 Toyota Highlander Side View Mirror Replacement: step 2, image 2 of 3 2006 Toyota Highlander Side View Mirror Replacement: step 2, image 3 of 3
    • Remove the door handle with the spudger by sliding it in from the side. Make sure to get it into the middle as there is a notch there holding it in place.
    • Note the arrows when replacing it.
    Ask FixBot
  3. 2006 Toyota Highlander Side View Mirror Replacement: step 3, image 1 of 2 2006 Toyota Highlander Side View Mirror Replacement: step 3, image 2 of 2
    • Remove the single Phillips screw hiding beneath.
    Ask FixBot
  4. 2006 Toyota Highlander Side View Mirror Replacement: step 4, image 1 of 3 2006 Toyota Highlander Side View Mirror Replacement: step 4, image 2 of 3 2006 Toyota Highlander Side View Mirror Replacement: step 4, image 3 of 3
    • In the door handle area, pry the small screw cover open with a spudger.
    • Remove the single screw with a Phillips screwdriver.
    Ask FixBot
  5. 2006 Toyota Highlander Side View Mirror Replacement: step 5, image 1 of 3 2006 Toyota Highlander Side View Mirror Replacement: step 5, image 2 of 3 2006 Toyota Highlander Side View Mirror Replacement: step 5, image 3 of 3
    • Place the wedge between the lock and the frame to pry the frame out.
    Ask FixBot
  6. 2006 Toyota Highlander Side View Mirror Replacement: step 6, image 1 of 1
    • Use a spudger to remove mirror cap.
    Ask FixBot
  7. 2006 Toyota Highlander Side View Mirror Replacement: step 7, image 1 of 3 2006 Toyota Highlander Side View Mirror Replacement: step 7, image 2 of 3 2006 Toyota Highlander Side View Mirror Replacement: step 7, image 3 of 3
    • Use a Phillips screwdriver (or any other sufficiently thin object) to push in the center piece. Use a spudger to remove the push cap.
    Ask FixBot
  8. 2006 Toyota Highlander Side View Mirror Replacement: step 8, image 1 of 1
    • Although not needed for now, push the push-cap back up to re-insert it later.
    Ask FixBot
  9. 2006 Toyota Highlander Side View Mirror Replacement: step 9, image 1 of 2 2006 Toyota Highlander Side View Mirror Replacement: step 9, image 2 of 2
    • Completely remove the door panel by feeling for a gap underneath the door. Use the heavy duty spudger to pop the door panel off.
    • When putting the door panel back on, make sure the master switch panel plug from step 1 is accessible, otherwise you may need to take panel off again to reach it.
    Ask FixBot
  10. 2006 Toyota Highlander Side View Mirror Replacement: step 10, image 1 of 2 2006 Toyota Highlander Side View Mirror Replacement: step 10, image 2 of 2
    • Take the door panel and lift it up and over to completely remove it from the door.
    Ask FixBot
  11. 2006 Toyota Highlander Side View Mirror Replacement: step 11, image 1 of 3 2006 Toyota Highlander Side View Mirror Replacement: step 11, image 2 of 3 2006 Toyota Highlander Side View Mirror Replacement: step 11, image 3 of 3
    • Remove the door courtesy light located at the bottom of the panel.
    Ask FixBot
  12. 2006 Toyota Highlander Side View Mirror Replacement: step 12, image 1 of 3 2006 Toyota Highlander Side View Mirror Replacement: step 12, image 2 of 3 2006 Toyota Highlander Side View Mirror Replacement: step 12, image 3 of 3
    • Check for plastic pins. If some are stuck do the door, use a clip to pull it out. Slide it back into the door panel for later.
    Ask FixBot
  13. 2006 Toyota Highlander Side View Mirror Replacement: step 13, image 1 of 2 2006 Toyota Highlander Side View Mirror Replacement: step 13, image 2 of 2
    • Detach the mirror's cable from the car.
    Ask FixBot
  14. 2006 Toyota Highlander Side View Mirror Replacement: step 14, image 1 of 1
    • Carefully remove tape from the wire using scissors.
    Ask FixBot
  15. 2006 Toyota Highlander Side View Mirror Replacement: step 15, image 1 of 2 2006 Toyota Highlander Side View Mirror Replacement: step 15, image 2 of 2
    • Unscrew the three bolts with a ratchet and a 10 mm socket.
    Ask FixBot
  16. 2006 Toyota Highlander Side View Mirror Replacement: step 16, image 1 of 1
    • Slowly pull the mirror out (make sure the connected wire also comes out).
    • Place in the new mirror by doing the above bullet point in reverse.
    • Note that there is a plastic covered "leg" above the wire. You will need to line this up with it's associated hole when putting in the new mirror.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. The reminder bullet points will notify you if any special actions are required for reassembly.
Anthony Ambartsoumian
253 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 44
All Time: 950
