2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement
  1. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement, Front Brake Master Cylinder: step 1, image 1 of 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement, Front Brake Master Cylinder: step 1, image 2 of 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement, Front Brake Master Cylinder: step 1, image 3 of 3
    • Turn the bike off and allow it to fully cool. Put nitrile gloves on before beginning.
    • Use a 3/32 inch Allen key to remove the bolt securing the brake lever.
    Ask FixBot
  2. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 2, image 1 of 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 2, image 2 of 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 2, image 3 of 3
    • Place a rag directly under the hose connection to catch any break fluid spills.
    • Use pliers to remove the clamp at the end of the reservoir hose.
    • Empty the brake fluid into an empty container.
    Ask FixBot
  3. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 3, image 1 of 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 3, image 2 of 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 3, image 3 of 3
    • Use an 8 mm socket attached to a 3/8 inch ratchet to remove the two bolts.
    Ask FixBot
  4. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 4, image 1 of 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 4, image 2 of 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 4, image 3 of 3
    • Grip the boot with your pliers and pull it out of its housing.
    • Use snap ring pliers to remove the snap ring behind the boot.
    Ask FixBot
  5. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 5, image 1 of 1
    • Use pliers to pull out the spring and piston assembly.
    Ask FixBot
  6. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 6, image 1 of 1
    • Check the condition of the master cylinder, and clean the cylinder with brake cleaner. Dry it with a rag.
    • If your master cylinder is corroded or in poor shape, you will need to buy a new or used master cylinder assembly and replace it.
    Ask FixBot
  7. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 7, image 1 of 1
    • Fit the new seals onto the piston.
    • Use a bit of new brake fluid as lubrication.
    Ask FixBot
  8. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 8, image 1 of 1
    • Place the new spring and piston back into the cylinder.
    Ask FixBot
  9. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 9, image 1 of 1
    • While holding the piston and spring down, use snap ring pliers to place the snap ring in the same orientation that it was taken out.
    • Use pliers to push the assembly together.
    Ask FixBot
  10. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 10, image 1 of 1
    • Replace the rubber boot.
    Ask FixBot
  11. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 11, image 1 of 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 11, image 2 of 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 11, image 3 of 3
    • Use an 8 mm socket attached to a 3/8 inch ratchet to secure the two bolts.
    • Use pliers to pinch the clamp until it is in the right position like the photo.
    • Replace your brake lever, then tighten the single bolt using a 3/32 inch Allen key.
    Ask FixBot
  12. 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 12, image 1 of 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 12, image 2 of 3 2006 Suzuki GSX-R600 Front Brake Master Cylinder Replacement: step 12, image 3 of 3
    • Remember to bleed the system while adding new fluid!
    • Refill the brake fluid reservoir to the appropriate level with new brake fluid.
    • Perform a quick test by pulling the brake lever and check that the front brake is functioning properly.
    • Congratulations! You are all done and ready to ride!
    Ask FixBot
Your front brake is now working as intended!
prabhmeet sidhu
205 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 71
All Time: 1,941
