2005 Mazda 6 Electronic Throttle Body Replacement
  1. 2005 Mazda 6 Electronic Throttle Body Replacement, Electronic Throttle Body: step 1, image 1 of 3 2005 Mazda 6 Electronic Throttle Body Replacement, Electronic Throttle Body: step 1, image 2 of 3 2005 Mazda 6 Electronic Throttle Body Replacement, Electronic Throttle Body: step 1, image 3 of 3
    • Open the hood and prop it open.
    • Locate the electronic throttle body.
    Ask FixBot
  2. 2005 Mazda 6 Electronic Throttle Body Replacement: step 2, image 1 of 3 2005 Mazda 6 Electronic Throttle Body Replacement: step 2, image 2 of 3 2005 Mazda 6 Electronic Throttle Body Replacement: step 2, image 3 of 3
    • Detach the electric connection from the electronic throttle body.
    • Unplug the safety pin.
    Ask FixBot
  3. 2005 Mazda 6 Electronic Throttle Body Replacement: step 3, image 1 of 2 2005 Mazda 6 Electronic Throttle Body Replacement: step 3, image 2 of 2
    • Unscrew the clamp that connects the intake hose to the air filter housing.
    Ask FixBot
  4. 2005 Mazda 6 Electronic Throttle Body Replacement: step 4, image 1 of 2 2005 Mazda 6 Electronic Throttle Body Replacement: step 4, image 2 of 2
    • Unscrew the clamp that secures the intake hose with the electronic throttle body.
    Ask FixBot
  5. 2005 Mazda 6 Electronic Throttle Body Replacement: step 5, image 1 of 3 2005 Mazda 6 Electronic Throttle Body Replacement: step 5, image 2 of 3 2005 Mazda 6 Electronic Throttle Body Replacement: step 5, image 3 of 3
    • Disconnect the intake hose from both sides.
    Ask FixBot
  6. 2005 Mazda 6 Electronic Throttle Body Replacement: step 6, image 1 of 3 2005 Mazda 6 Electronic Throttle Body Replacement: step 6, image 2 of 3 2005 Mazda 6 Electronic Throttle Body Replacement: step 6, image 3 of 3
    • Disconnect the upper and lower vacuum hose on the electronic throttle body using a pair of pliers.
    Ask FixBot
  7. 2005 Mazda 6 Electronic Throttle Body Replacement: step 7, image 1 of 3 2005 Mazda 6 Electronic Throttle Body Replacement: step 7, image 2 of 3 2005 Mazda 6 Electronic Throttle Body Replacement: step 7, image 3 of 3
    • Remove the four screws connecting the electronic throttle body to the intake manifold.
    Ask FixBot
  8. 2005 Mazda 6 Electronic Throttle Body Replacement: step 8, image 1 of 2 2005 Mazda 6 Electronic Throttle Body Replacement: step 8, image 2 of 2
    • Place the new electronic throttle body on the intake manifold.
    Ask FixBot
  9. 2005 Mazda 6 Electronic Throttle Body Replacement: step 9, image 1 of 2 2005 Mazda 6 Electronic Throttle Body Replacement: step 9, image 2 of 2
    • Reattach the four screws securing the electronic throttle body with the intake manifold.
    Ask FixBot
  10. 2005 Mazda 6 Electronic Throttle Body Replacement: step 10, image 1 of 3 2005 Mazda 6 Electronic Throttle Body Replacement: step 10, image 2 of 3 2005 Mazda 6 Electronic Throttle Body Replacement: step 10, image 3 of 3
    • Connect the upper vacuum.
    • Connect the lower vacuum hose to the electronic throttle body.
    Ask FixBot
  11. 2005 Mazda 6 Electronic Throttle Body Replacement: step 11, image 1 of 3 2005 Mazda 6 Electronic Throttle Body Replacement: step 11, image 2 of 3 2005 Mazda 6 Electronic Throttle Body Replacement: step 11, image 3 of 3
    • Connect the intake hose on both sides.
    • Screw in the clamp that secures the intake hose to the electronic throttle body.
    • Screw the clamp that secures the intake hose to the air filter housing.
    Ask FixBot
  12. 2005 Mazda 6 Electronic Throttle Body Replacement: step 12, image 1 of 3 2005 Mazda 6 Electronic Throttle Body Replacement: step 12, image 2 of 3 2005 Mazda 6 Electronic Throttle Body Replacement: step 12, image 3 of 3
    • Connect the electric connection to the electronic throttle body.
    Ask FixBot
  13. 2005 Mazda 6 Electronic Throttle Body Replacement: step 13, image 1 of 2 2005 Mazda 6 Electronic Throttle Body Replacement: step 13, image 2 of 2
    • The electronic throttle body replacement is done.
    Ask FixBot
Finish Line
6 other people completed this guide.
Yefri Gonzalez
379 Reputation
1 Guide authored
1 Guide Comment
Bonjour j'ai un Mazda 6 de moteur Essence avec moi mais sa consomme trop et Quel est la solution pour d'autre me disent de changer le catalyseur d'autres me disent de changer la bougie
Sidi mohamed Coulibaly - Reply Share
Past 24 Hours: 8
Past 7 Days: 51
Past 30 Days: 209
All Time: 4,932
