Up to 20% off select tools
2003 Acura TL Window Regulator Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
71
All Time:
565
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 2 hours
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Parts
Tools
Introduction
Go to step 1 ↓
This guide demonstrates how to replace a broken window regulator in a 1999-2003 Acura TL. If your window regulator can no longer roll up, it may be a sign that it's time for a replacement. While it may be hard to find information about a car over twenty years old, this guide can help fill in those gaps.
Steps in this version may be different from disassembling the driver's side door, as the driver's side door involves additional steps. Alternatively, I have provided notes during the steps to help distinguish the differences and try to assist regardless.
Caution: This repair may be difficult without another set of hands. If possible, get someone to help you to avoid any accidents or injury.
    1. 2003 Acura TL Window Regulator Replacement, Window Regulator: step 1, image 1 of 3 2003 Acura TL Window Regulator Replacement, Window Regulator: step 1, image 2 of 3 2003 Acura TL Window Regulator Replacement, Window Regulator: step 1, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the screw covers and screws behind the door handle and on the center doorframe.
      • Set them aside for reassembly.
      • If you're working on reassembling specifically the front driver's side door, you may have to remove the handle by shifting it right, then detaching it by unplugging the memory board located on the back. Other passenger doors won't have this additional step.
      Ask FixBot
    2. 2003 Acura TL Window Regulator Replacement: step 2, image 1 of 3 2003 Acura TL Window Regulator Replacement: step 2, image 2 of 3 2003 Acura TL Window Regulator Replacement: step 2, image 3 of 3
      • Using a trim removal tool, begin separating the door cover from the door. While separating, carefully undo the clips attaching the door to its frame.
      • The clips are very fragile. Ensure the clips don't get damaged during separation.
      Ask FixBot
    3. 2003 Acura TL Window Regulator Replacement: step 3, image 1 of 1
      • Carefully unplug the speaker and window control cable connectors from the door. Press down on each connector to release it from its socket.
      • The driver's side door, which has a memory board, may have additional wires to disconnect.
      Ask FixBot
    4. 2003 Acura TL Window Regulator Replacement: step 4, image 1 of 2 2003 Acura TL Window Regulator Replacement: step 4, image 2 of 2
      • Carefully pull off the weather seal so you have access to the internal part of the door.
      • Try to avoid tearing it as you will need to use it once you are done with the repair.
      Ask FixBot
    5. 2003 Acura TL Window Regulator Replacement: step 5, image 1 of 2 2003 Acura TL Window Regulator Replacement: step 5, image 2 of 2
      • If your window motor is already broken, you may have trouble keeping your window pane from falling if you are working by yourself.
      • Place a solid wood stick or other material in the door cavity below the window to prop the pane up.
      • The stick is to ensure the pane is properly secured when removing the window pane, but it may not be necessary if you're working on this project with someone else. Additionally, if you don't have a stick or an extra set of hands, try using durable tape to secure the glass to the top of the frame.
      Ask FixBot
    6. 2003 Acura TL Window Regulator Replacement: step 6, image 1 of 3 2003 Acura TL Window Regulator Replacement: step 6, image 2 of 3 2003 Acura TL Window Regulator Replacement: step 6, image 3 of 3
      • Use a socket wrench to unscrew the bolts attaching the window regulator to the doorframe.
      • You may need to tear the weather seal back more to have better access to the bolts.
      Ask FixBot
    7. 2003 Acura TL Window Regulator Replacement: step 7, image 1 of 3 2003 Acura TL Window Regulator Replacement: step 7, image 2 of 3 2003 Acura TL Window Regulator Replacement: step 7, image 3 of 3
      • Push the bolts out from inside the doorframe.
      • Remove the window regulator.
      • Replace the old window regulator with the new one, rescrewing bolts and reassembling the doorframe.
      Ask FixBot
Author
with
Vince Vanzura
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 71
All Time: 565
