2001 Volvo s40 Thermostat Replacement
  1. 2001 Volvo s40 Thermostat Replacement, Thermostat: step 1, image 1 of 1
    • MAKE SURE ENGINE IS COLD Locate the upper radiator hose and follow it to the location where the hose connects to the engine block. The hose clamps to a metal housing called the "water inlet." Loosen the band clamp that secures the hose to the water inlet with a screwdriver. Pull the hose off the inlet.
    Ask FixBot
  2. 2001 Volvo s40 Thermostat Replacement: step 2, image 1 of 1
    • Locate the two bolts that secure the inlet to the engine block and remove them. Use a 12 mm socket and ratchet. Pull the water inlet off the engine block. Due to age, the inlet may stick to the block. Place pressure on the side of the inlet to break the seal, if needed.
    Ask FixBot
    • Scrape the base of the engine and the bottom of the inlet to remove the old gasket material and to clean the mating surfaces.
    Ask FixBot
  3. 2001 Volvo s40 Thermostat Replacement: step 4, image 1 of 1
    • Pull the old thermostat out of the engine and place the new one into the engine. One end of the thermostat has a large spring. The spring sits inside of the engine.
    Ask FixBot
    • Place a bead of RTV gasket maker around the bottom edge of the water inlet. Place the water inlet over the thermostat and bolt it into place. Using RTV gasket maker instead of a gasket compensates for pitting that occurs in cast iron. It helps to promote a better seal between the engine and the inlet.
    Ask FixBot
    • Slide the radiator hose onto the inlet and secure it with the band clamp.
    Ask FixBot
4 other people completed this guide.
Josef
217 Reputation
1 Guide authored
1 Guide Comment
When I start the car it's shack and the gass race go up and down
Samir Alrheis - Reply Share
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 56
All Time: 8,345
