2001 Audi TT Rear Differential Replacement
  1. 2001 Audi TT Rear Differential Replacement, Getting Started: step 1, image 1 of 1
    • Lets get started! A car lift is recommended for this task but it can be done with just a jack if required.
    Ask FixBot
  2. 2001 Audi TT Rear Differential Replacement, Remove the exaust and exaust shield: step 2, image 1 of 1
    • The exhaust is held in with two bolts at the middle of car underneath . It the hangs from 4 rubber mount wich can be unhooked with a small screw driver and some leverage.
    • Be careful not to tear the rubber mounts.
    • Sorry for missing images they were never taken during the exhaust removal.
    Ask FixBot
  3. 2001 Audi TT Rear Differential Replacement, Axles: step 3, image 1 of 1
    • Dismount both axles from the rear differential.
    Ask FixBot
  4. 2001 Audi TT Rear Differential Replacement, Ground Strap: step 4, image 1 of 1
    • Dismount the ground strap located to the left of the driver side rear axle hub.
    Ask FixBot
  5. 2001 Audi TT Rear Differential Replacement, Drive Line Hub: step 5, image 1 of 1
    • Dismount the drive line from the rear differential.
    Ask FixBot
  6. 2001 Audi TT Rear Differential Replacement, Remove Tank Shield: step 6, image 1 of 1
    • Removing the passenger side gas tank shield will make step 7 easier.
    Ask FixBot
  7. 2001 Audi TT Rear Differential Replacement, Remove Bracket: step 7, image 1 of 2 2001 Audi TT Rear Differential Replacement, Remove Bracket: step 7, image 2 of 2
    • Remover the two main bolts.
    Ask FixBot
  8. 2001 Audi TT Rear Differential Replacement, Remove Bracket 2: step 8, image 1 of 2 2001 Audi TT Rear Differential Replacement, Remove Bracket 2: step 8, image 2 of 2
    • Remove other smaller bolts.
    Ask FixBot
  9. 2001 Audi TT Rear Differential Replacement, Unbolt From Car: step 9, image 1 of 1
    • Remove the 4 bolts on both sides that hold the rear differential in the car.
    • Be sure to have some sort of jack or object to hold the rear differential into the car as you continue to work.
    Ask FixBot
2 other people completed this guide.
Brenden Mitchell
223 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 34
Past 30 Days: 113
All Time: 5,334
