2000 Toyota 4Runner Dashboard Light Bulbs Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
Past 7 Days:
29
Past 30 Days:
127
All Time:
2,066
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes - 1 hour
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This is a guide to replacing the light bulb on the dashboard of a 2000 Toyota 4Runner. After replacing the light bulbs they will need to be recycled. Replacing the dashboard light bulbs there gives the driver a better visual of the warning light or driving at night time.
    1. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement, Dashboard Light Bulbs: step 1, image 1 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement, Dashboard Light Bulbs: step 1, image 2 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement, Dashboard Light Bulbs: step 1, image 3 of 3
      • Remove the car key from the ignition so there isn't a current running through the car while working on it and to have more room.
      Ask FixBot
    2. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 2, image 1 of 2 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 2, image 2 of 2
      • On the left side of the steering column, there is a lever that, by pulling forward, allows you to adjust the steering wheel's position.
      Ask FixBot
    3. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 3, image 1 of 2 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 3, image 2 of 2
      • Pull the lever on the left side of the steering column while moving the steering wheel up or down to make some room.
      Ask FixBot
    4. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 4, image 1 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 4, image 2 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 4, image 3 of 3
      • Use a 10 mm socket on a ratchet wrench to remove the two 10 mm bolts near the steering column.
      Ask FixBot
    5. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 5, image 1 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 5, image 2 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 5, image 3 of 3
      • Remove the other two 10 mm bolts that are closer to the pedals.
      • When removing the 10 mm bolt on the bottom left corner, it will be easier to open the car door to reach it.
      Ask FixBot
    6. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 6, image 1 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 6, image 2 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 6, image 3 of 3
      • Gently pull the cover downwards.
      • Gently rest the cover on the floorboard so that the wires and cables don't get damaged.
      Ask FixBot
    7. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 7, image 1 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 7, image 2 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 7, image 3 of 3
      • Grab onto the light-dimmer cap on the left side of the steering and gently pull it out.
      • Use a 12 mm socket to remove the 12 mm nut holding the dimmer switch in place.
      Ask FixBot
    8. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 8, image 1 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 8, image 2 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 8, image 3 of 3
      • On the right side of the steering column, grab onto the ignition cover and pull on it gently to take it off.
      • The trim piece may break if pulled too forcefully.
      Ask FixBot
    9. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 9, image 1 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 9, image 2 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 9, image 3 of 3
      • Use a screwdriver to remove the two 1/2 inch screws from the bottom part of the gauge cluster trim piece.
      Ask FixBot
    10. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 10, image 1 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 10, image 2 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 10, image 3 of 3
      • Remove the two top 1/2 inch screws of the trim piece.
      Ask FixBot
    11. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 11, image 1 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 11, image 2 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 11, image 3 of 3
      • Grab onto the gauge cluster trim and remove it.
      Ask FixBot
    12. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 12, image 1 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 12, image 2 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 12, image 3 of 3
      • Use the screwdriver to remove the two top 1/2-inch screws that hold the gauge cluster in place.
      Ask FixBot
    13. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 13, image 1 of 2 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 13, image 2 of 2
      • Unscrew the bottom two 1/2 inch screws that hold in the gauge cluster.
      Ask FixBot
    14. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 14, image 1 of 2 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 14, image 2 of 2
      • Grab onto the gauge cluster once all four screws have been removed and pull it forward to be able to reach the connection on the backside.
      • Pulling too hard may damage the connection in to the back of gauge cluster.
      Ask FixBot
    15. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 15, image 1 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 15, image 2 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 15, image 3 of 3
      • On the right side of the gauge cluster, there is one brown connection that needs to be disconnected.
      Ask FixBot
    16. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 16, image 1 of 2 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 16, image 2 of 2
      • On the left side of the gauge cluster, there is one white connection that needs to be disconnected.
      Ask FixBot
    17. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 17, image 1 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 17, image 2 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 17, image 3 of 3
      • In the middle of the gauge cluster, there is one white connection that is closer to the left side that needs to be disconnected.
      Ask FixBot
    18. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 18, image 1 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 18, image 2 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 18, image 3 of 3
      • In the middle of the gauge cluster, there is one blue connection that is closer to the right side that needs to be disconnected.
      • Remove the gauge cluster from the dashboard.
      Ask FixBot
    19. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 19, image 1 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 19, image 2 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 19, image 3 of 3
      • Grab onto the light bulb housing and turn it counter-clockwise until it clicks out of place.
      • Remove from the back of the gauge cluster.
      Ask FixBot
    20. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 20, image 1 of 2 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 20, image 2 of 2
      • Grab onto the 74 fluorescent light bulb and pull it out of the housing.
      Ask FixBot
    21. 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 21, image 1 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 21, image 2 of 3 2000 Toyota 4Runner Dashboard Light Bulbs Replacement: step 21, image 3 of 3
      • Grab a new 74 fluorescent light bulb and push back into the housing.
      • If you decide to replace the light bulbs with LED bulbs instead of fluorescent then you will have to test the connection by plugging in the connections and turning the key to the run position.
      • LED bulbs only function if they are in a certain orientation so just pull out the housing turn 180 degrees and test it again.
      Ask FixBot
Mauricio Castro
340 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 29
Past 30 Days: 127
All Time: 2,066
