2000 Porsche Boxter Headlight Bulb Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
102
All Time:
863
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace a malfunctioning or unusable headlight bulb on a 2000 Porsche Boxster.
The car’s headlight bulb is a crucial component of the lighting system, providing visibility for night driving and ensuring that other drivers can see your vehicle. Over time, bulbs can burn out, become dim, or suffer from electrical issues, necessitating replacement. Your headlight bulb may need to be replaced if it has burned out, is flickering, or appears significantly dimmer than usual. In some cases, condensation inside the headlight housing or wiring issues can also lead to malfunctioning bulbs. For this guide, you will need an Allen wrench, which is typically included with the car, but you may need to purchase one separately. You will also need a replacement bulb that is compatible with the 2000 Porsche Boxster. Our guide recommends using a H7 Standard Halogen light bulb (H7 for low beam, H1 for high beam).
Follow this guide carefully to ensure proper installation and safety during the headlight replacement process. Before beginning, make sure your car’s engine is turned off completely and parked.
    1. 2000 Porsche Boxter Headlight Bulb Replacement, Headlight Bulb: step 1, image 1 of 1
      • Open the front trunk (frunk) using the latch on the left side of the driver’s seat.
      Ask FixBot
    2. 2000 Porsche Boxter Headlight Bulb Replacement: step 2, image 1 of 3 2000 Porsche Boxter Headlight Bulb Replacement: step 2, image 2 of 3 2000 Porsche Boxter Headlight Bulb Replacement: step 2, image 3 of 3
      • Look inside the frunk side panel on the side of the headlight you wish to replace.
      • Unscrew the black clip that holds the side panel to the car, and peel it back.
      Ask FixBot
    3. 2000 Porsche Boxter Headlight Bulb Replacement: step 3, image 1 of 1
      • Insert the 5 mm Allen wrench into the locking mechanism, and turn it counterclockwise until you hear a “pop” sound.
      Ask FixBot
    4. 2000 Porsche Boxter Headlight Bulb Replacement: step 4, image 1 of 3 2000 Porsche Boxter Headlight Bulb Replacement: step 4, image 2 of 3 2000 Porsche Boxter Headlight Bulb Replacement: step 4, image 3 of 3
      • The headlight will be loose now.
      • Carefully slide the headlight forward out of the car.
      Ask FixBot
    5. 2000 Porsche Boxter Headlight Bulb Replacement: step 5, image 1 of 3 2000 Porsche Boxter Headlight Bulb Replacement: step 5, image 2 of 3 2000 Porsche Boxter Headlight Bulb Replacement: step 5, image 3 of 3
      • Remove the plastic cover from the back of the headlight, by pressing the clip that reads PUSH.
      • Pull off and remove the cover, placing it aside.
      • You will see two wire plugs after removing the cover.
      Ask FixBot
    6. 2000 Porsche Boxter Headlight Bulb Replacement: step 6, image 1 of 1
      • Carefully disconnect the wire plug where you wish to replace the bulb.
      • If necessary, gently wiggle it side-to-side while pulling.
      Ask FixBot
    7. 2000 Porsche Boxter Headlight Bulb Replacement: step 7, image 1 of 2 2000 Porsche Boxter Headlight Bulb Replacement: step 7, image 2 of 2
      • The old bulb is secured with a metal clip.
      • Carefully press the retaining spring clip and release it.
      • Once the clip is released, lift it up completely to fully open it, leaving the bulb loose.
      Ask FixBot
    8. 2000 Porsche Boxter Headlight Bulb Replacement: step 8, image 1 of 2 2000 Porsche Boxter Headlight Bulb Replacement: step 8, image 2 of 2
      • Avoid touching the glass of the new bulb with bare fingers—oil from your skin can shorten its lifespan.
      • Gently pull the old bulb out, and insert the new H7 or H1 bulb, with the bulb side facing towards the entrypoint.
      Ask FixBot
    9. 2000 Porsche Boxter Headlight Bulb Replacement: step 9, image 1 of 3 2000 Porsche Boxter Headlight Bulb Replacement: step 9, image 2 of 3 2000 Porsche Boxter Headlight Bulb Replacement: step 9, image 3 of 3
      • Ensure the wiring is restored to its original layout; otherwise the bulb will not illuminate.
      • Make sure the metal notch of the bulb is aligned properly with the bulb housing.
      • Secure the retaining clip back in place.
      • Reconnect the wiring plug back in.
      Ask FixBot
    10. 2000 Porsche Boxter Headlight Bulb Replacement: step 10, image 1 of 1
      • Reattach the plastic cover back in place by alligning its attachment points, then gently press it into place.
      • Secure by pressing down the PUSH button to ensure it clicks, and preventing the cover from detaching.
      Ask FixBot
    11. 2000 Porsche Boxter Headlight Bulb Replacement: step 11, image 1 of 3 2000 Porsche Boxter Headlight Bulb Replacement: step 11, image 2 of 3 2000 Porsche Boxter Headlight Bulb Replacement: step 11, image 3 of 3
      • Line up the headlight connector and the car slot before sliding the headlight in.
      Ask FixBot
    12. 2000 Porsche Boxter Headlight Bulb Replacement: step 12, image 1 of 2 2000 Porsche Boxter Headlight Bulb Replacement: step 12, image 2 of 2
      • If the headlight doesn’t align properly, remove and reset it before locking in place.
      • Carefully slide the headlight back into its slot.
      • Use the 5mm Allen wrench and turn the locking mechanism clockwise to lock the headlight back in place.
      • You should hear a “pop” once it is secured.
      Ask FixBot
    13. 2000 Porsche Boxter Headlight Bulb Replacement: step 13, image 1 of 1
      • Gently pull to ensure the headlight is stable and doesn’t move.
      • Place the side panel back in place and screw the black clip back on.
      Ask FixBot
    14. 2000 Porsche Boxter Headlight Bulb Replacement: step 14, image 1 of 1
      • If light still doesn’t work, check the fuse box for a blown fuse.
      • Close the frunk and turn on the car.
      • Switch on the headlights and verify the new bulb is working properly.
      Ask FixBot
Finish Line
JasmineG
229 Reputation
1 Guide authored
UC Davis, Team 2-2, Andersen Winter 2025 Member of UC Davis, Team 2-2, Andersen Winter 2025
UCD-ANDERSEN-W25S2G2
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 102
All Time: 863
