1997 Saturn II Passenger Side Mirror Replacement
  1. 1997 Saturn II Passenger Side Mirror Replacement, Passenger Side Mirror: step 1, image 1 of 3 1997 Saturn II Passenger Side Mirror Replacement, Passenger Side Mirror: step 1, image 2 of 3 1997 Saturn II Passenger Side Mirror Replacement, Passenger Side Mirror: step 1, image 3 of 3
    • Pry the plastic panel away from the base of the side mirror with a metal spudger or your hands.
    Ask FixBot
  2. 1997 Saturn II Passenger Side Mirror Replacement: step 2, image 1 of 3 1997 Saturn II Passenger Side Mirror Replacement: step 2, image 2 of 3 1997 Saturn II Passenger Side Mirror Replacement: step 2, image 3 of 3
    • Remove the three 10 mm bolts using the 10 mm socket and ratchet extension.
    • If there is an existing side mirror attached, hold it to keep it from falling.
    Ask FixBot
  3. 1997 Saturn II Passenger Side Mirror Replacement: step 3, image 1 of 1
    • Remove the existing side mirror if there is one attached.
    Ask FixBot
  4. 1997 Saturn II Passenger Side Mirror Replacement: step 4, image 1 of 1
    • Mount the replacement passenger side mirror.
    • Ensure it lays flat with the car.
    Ask FixBot
  5. 1997 Saturn II Passenger Side Mirror Replacement: step 5, image 1 of 3 1997 Saturn II Passenger Side Mirror Replacement: step 5, image 2 of 3 1997 Saturn II Passenger Side Mirror Replacement: step 5, image 3 of 3
    • Hold the side mirror in the slot.
    • Tighten one 10 mm bolt as much as you can by hand first to keep the mirror in place, and then tighten the remaining two 10 mm bolts.
    Ask FixBot
  6. 1997 Saturn II Passenger Side Mirror Replacement: step 6, image 1 of 2 1997 Saturn II Passenger Side Mirror Replacement: step 6, image 2 of 2
    • Replace the plastic panel by snapping it back on.
    Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 48
All Time: 923
