12-inch Sprinkler Head Replacement
  1. 12-inch Sprinkler Head Replacement, 12-inch Sprinkler Head: step 1, image 1 of 3 12-inch Sprinkler Head Replacement, 12-inch Sprinkler Head: step 1, image 2 of 3 12-inch Sprinkler Head Replacement, 12-inch Sprinkler Head: step 1, image 3 of 3
    • Dig and remove dirt around the existing sprinkler head and several inches around connected PVC.
    • Place the dirt in 5 gallon the buckets or on the surface near the hole.
    • Dig until the hole is at least 14 inches below the PVC pipe allowing room for the flex riser.
    Ask FixBot
  2. 12-inch Sprinkler Head Replacement: step 2, image 1 of 3 12-inch Sprinkler Head Replacement: step 2, image 2 of 3 12-inch Sprinkler Head Replacement: step 2, image 3 of 3
    • Rinse all around the sprinkler head and PVC with water.
    • This will allow for a clean installation of the new sprinkler parts and keep the dirt from entering the new parts.
    Ask FixBot
  3. 12-inch Sprinkler Head Replacement: step 3, image 1 of 3 12-inch Sprinkler Head Replacement: step 3, image 2 of 3 12-inch Sprinkler Head Replacement: step 3, image 3 of 3
    • Remove the old sprinkler head and riser.
    • Turn counterclockwise until the old sprinkler head and or riser is removed.
    • Rinse area for clean installation.
    Ask FixBot
  4. 12-inch Sprinkler Head Replacement: step 4, image 1 of 3 12-inch Sprinkler Head Replacement: step 4, image 2 of 3 12-inch Sprinkler Head Replacement: step 4, image 3 of 3
    • For this step, wrap 4 threaded ends with Teflon tape: both ends of the flex riser and one end of each swing joint elbows.
    • Wrap Teflon tape clockwise around the threaded part of each of the above-mentioned sprinkler connections.
    • Put three complete layers of tape on each of the threaded ends. This will allow for a tighter and secure fit.
    Ask FixBot
  5. 12-inch Sprinkler Head Replacement: step 5, image 1 of 3 12-inch Sprinkler Head Replacement: step 5, image 2 of 3 12-inch Sprinkler Head Replacement: step 5, image 3 of 3
    • Screw clockwise, the new Teflon wrapped the threaded part of an elbow, into the pipe in the ground.
    • This is the location of the old sprinkler head and riser.
    • Confirm that the part is installed snugly and not cross-threaded.
    • Caution: Do not over tighten.
    Ask FixBot
  6. 12-inch Sprinkler Head Replacement: step 6, image 1 of 2 12-inch Sprinkler Head Replacement: step 6, image 2 of 2
    • Screw the threaded end of the elbow onto the 12" sprinkler head.
    Ask FixBot
  7. 12-inch Sprinkler Head Replacement: step 7, image 1 of 3 12-inch Sprinkler Head Replacement: step 7, image 2 of 3 12-inch Sprinkler Head Replacement: step 7, image 3 of 3
    • Confirm that Teflon tape has been applied to both threaded ends.
    • Screw one end of the blue flex tubing onto the elbow in the previous step.
    • Screw the other end of the flex tubing onto the last remaining elbow.
    • Caution: Confirm that the part is installed snugly and not cross-threaded. Do not over tighten.
    Ask FixBot
  8. 12-inch Sprinkler Head Replacement: step 8, image 1 of 3 12-inch Sprinkler Head Replacement: step 8, image 2 of 3 12-inch Sprinkler Head Replacement: step 8, image 3 of 3
    • Lower the 12-inch sprinkler head and flex tubing down into the hole.
    • Adjust the new sprinkler head so it is level with the sidewalk or surface.
    • Adjust flex tubing as necessary so that there are no kinks and that the joints are still tight.
    Ask FixBot
  9. 12-inch Sprinkler Head Replacement: step 9, image 1 of 1
    • Test the new parts to confirm that there are no leaks.
    • Guard your eyes and other things that you don't want to get wet.
    Ask FixBot
  10. 12-inch Sprinkler Head Replacement: step 10, image 1 of 3 12-inch Sprinkler Head Replacement: step 10, image 2 of 3 12-inch Sprinkler Head Replacement: step 10, image 3 of 3
    • Hold the sprinkler head in place, vertically, while carefully putting the dirt into the ground by hand. Using your hands allows for a gentle pressure on the sprinkler head versus using a tool that could crack or break it.
    • Add dirt in layers, compressing the dirt by hand, around the sprinkler head.
    • Do not compress the dirt too much, as the tubing can be crushed.
    Ask FixBot
  11. 12-inch Sprinkler Head Replacement: step 11, image 1 of 2 12-inch Sprinkler Head Replacement: step 11, image 2 of 2
    • Turn on the sprinkler system.
    • At this point full water flow should come out of the new sprinkler head.
    • If the flow is good, adjust the nozzle direction and radius by turning the nozzle head and shaft.
    • Check water pressure and nozzle lift after landscaping has returned around sprinkler head.
    Ask FixBot
PATRICIA ANN FOURNIER
193 Reputation
1 Guide authored
CSU Sacramento, Team 1-1, Laflen Fall 2024 Member of CSU Sacramento, Team 1-1, Laflen Fall 2024
CSUSAC-LAFLEN-F24S1G1
1 Member
1 Guide authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 79
Past 30 Days: 373
All Time: 993
