Up to 20% off select tools
12-String Takamine G Series Guitar String Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
29
Past 30 Days:
132
All Time:
1,302
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Guitar strings tend to break often, especially on 12-string guitars because of the high tension. This guide will teach you how to replace one of those strings if they do happen to break.
The last step requires you to tighten the string in order to tune the guitar. 12-string guitars will be tuned differently depending on how your strings are arranged. A 12-string guitar with paired strings will have all pairs of strings tuned exactly the same, whereas a regular 12-string guitar will have one string from the pair tuned an octave higher.
    1. 12-String Takamine G Series Guitar String Replacement, Guitar String: step 1, image 1 of 3 12-String Takamine G Series Guitar String Replacement, Guitar String: step 1, image 2 of 3 12-String Takamine G Series Guitar String Replacement, Guitar String: step 1, image 3 of 3
      • Turn the tuning peg corresponding to the string you want to change clockwise until the string is completely loose.
      • This is only if the string is damaged but not completely broken (if the string is completely broken skip to step 2).
      Ask FixBot
    2. 12-String Takamine G Series Guitar String Replacement: step 2, image 1 of 2 12-String Takamine G Series Guitar String Replacement: step 2, image 2 of 2
      • Use wire cutters to take out the pins located on the bridge of the guitar and completely release the string from the guitar.
      Ask FixBot
    3. 12-String Takamine G Series Guitar String Replacement: step 3, image 1 of 2 12-String Takamine G Series Guitar String Replacement: step 3, image 2 of 2
      • Place the new string into the hole in the bridge where the pin was taken out.
      Ask FixBot
    4. 12-String Takamine G Series Guitar String Replacement: step 4, image 1 of 3 12-String Takamine G Series Guitar String Replacement: step 4, image 2 of 3 12-String Takamine G Series Guitar String Replacement: step 4, image 3 of 3
      • Place the pin back into the hole to secure the string.
      Ask FixBot
    5. 12-String Takamine G Series Guitar String Replacement: step 5, image 1 of 1
      • Grab the string and put it through the hole located on the tuning post of the guitar.
      Ask FixBot
    6. 12-String Takamine G Series Guitar String Replacement: step 6, image 1 of 3 12-String Takamine G Series Guitar String Replacement: step 6, image 2 of 3 12-String Takamine G Series Guitar String Replacement: step 6, image 3 of 3
      • Take the string and wrap it around and underneath itself.
      • Pull the string taught.
      • Twist the string over itself and than cut off the excess string.
      Ask FixBot
    7. 12-String Takamine G Series Guitar String Replacement: step 7, image 1 of 2 12-String Takamine G Series Guitar String Replacement: step 7, image 2 of 2
      • Turn the tuning peg counterclockwise to tighten the string.
      Ask FixBot
Author
with
Rey Navarro
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 132
All Time: 1,302
