Up to 20% off select tools
1. Y Axis Frame
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
63
All Time:
670
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
1. Y Axis Frame
Tools
Video Overview
    1. 1. Y Axis Frame, preparing the components: step 1, image 1 of 1
      • 2 X axis member
      • 2 Y axis member
      • 4 L bracket (Printed or Laser cut)
      • 4 Rubber feet
      • 4 M8 x 40mm socket screws
      • 8 M6 x 12mm socket screws
      • 4 M6 x 20mm socket screws
      • 12 T-slot nuts
      Ask FixBot
    2. 1. Y Axis Frame: step 2, image 1 of 3 1. Y Axis Frame: step 2, image 2 of 3 1. Y Axis Frame: step 2, image 3 of 3
      • Make sure the sockets for the screws are aligned and in the same side.
      • Using the M8 x 40 screws, join the X and Y members
      • Tighten just enough to keep the frame assemble together.
      Ask FixBot
    3. 1. Y Axis Frame: step 3, image 1 of 3 1. Y Axis Frame: step 3, image 2 of 3 1. Y Axis Frame: step 3, image 3 of 3
      • Locate the bottom of the frame, where the socket for the head of the screw is drilled.
      • On the L bracket place
      • 2 M6 x 12mm screws
      • 1 M6 x 20mm screw
      • Align on the extrusion and tighten the screws
      Ask FixBot
Author
with
Juan Francisco
152 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 63
All Time: 670
