Up to 20% off select tools
Guides
Background and Identification
The first unibody iMac was released in October of 2009, replacing the 20 and 24 inch versions of the second generation. Not to be confused with the 21.5” version, this iMac measures 27 inches across opposite corners and came with options for the Intel i-series chips not available initially in the smaller version. The plastic panel that made up the backs of the older generation is replaced with an aluminum enclosure which extends around the sides and front to form a single piece. The RAM slots are also doubled from the previous generation (from 2 to 4) along with the memory capacity (to 32GB).
In 2012, Apple slimmed down the iMac for the 4th generation, albeit at the expense of the SuperDrive optical drive. While the 21.5” version saw some decreases in repairability during this generation, the 27” model retained a service cover to allow the user to upgrade the RAM without removing the display and motherboard. The fourth generation continues to be produced, with the latest update having been announced in 2017. However, Apple released a 5th generation Retina iMac in October of 2014, to be produced alongside the non-Retina versions. The Retina model came with upgraded Thunderbolt ports and better spec options, along with the improved display synonymous with the Retina name.
These models of the iMac continue to be produced today, although their design has not deviated much from the version released in 2012. In order to properly identify your Mac, either check the “About this Mac” section under the apple icon in the top left corner of your screen, or find your computer’s model number in the middle of the bottom edge of the computer’s display and use a Mac Serial Number Lookup Tool to find your model.
Additional Information
  • Not sure which model you have? Open the page for your model in this category and check its Identification section.
  • Wikipedia - iMac
Author
with
Sam Goldheart
478,971 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 104
Past 7 Days: 776
Past 30 Days: 3,445
All Time: 1,840,075
